jvernan
What battery do I need based on these components?
Sun Sep 23, 2018 12:01 am
I am thinking about using USB 5V Voltage Booster Step Up Module, with a lipo battery of 3.7v and 2500 mah?
klricks
Re: What battery do I need based on these components?
Sun Sep 23, 2018 12:35 am
1.- raspberry pi 3
2.- Sim800L
3.- usb-ttl
4.- ublox neo 6m gps
5.- camera
6.- ADC ADS1015
7.- Sharp-2Y0A21
You will need to gather current specifications from the product datasheets OR better... Neasure the actual current usage of your complete system while in operation.
Decide how many minutes of run time you need.
Buy a USB powerbank that can meet your requirements if possible.
I am guessing the setup you mentioned will run 30 min to an hour?
LTolledo
Sun Sep 23, 2018 12:40 am
How about using 8D battery and a few buck converters......
Some people be like:
W. H. Heydt
Sun Sep 23, 2018 2:02 am
At a rough calculation--with what you've shown--you're going to need something more than a 3A supply. It would probably be best to spec your PSU for 4A. In addition, you've "low balled" the power for the Pi3B. The fully loaded spec for a Pi3B is 2.4A, though that allows for 1.2A to the USB ports. If any of the peripherals are going to be connected to the USB ports, you can adjust your total power requirements accordingly.
You really need to build your full hardware config and *measure* the power requirements.
grahamed
Sun Sep 23, 2018 5:59 pm
The current for the USB-serial is suspiciously large, not more than 50mA and probbly more like 25mA.
The current draw of the devices is the same whether they are pugged into the Pi USB ports or elsewhere; why assume a fully loaded Pi and then count them twice?
