kdeuler
Hostname option missing from raspi-config
Fri Sep 21, 2018 6:15 pm
Hi. I'm trying to change the hostname of my RPi 3 using raspi-config. However, I'm not seeing a "hostname" option in the main menu or any submenus, contrary to guidance on various websites. Has this option been removed?
I installed Raspian Lite directly (not via noobs).
Thanks!
epoch1970
Re: Hostname option missing from raspi-config
Fri Sep 21, 2018 6:22 pm
Curious.
But you can work around the issue easily: "sudo nano /etc/hostname", save and reboot.
DirkS
Fri Sep 21, 2018 6:25 pm
On current Raspbian it should be 2 (Network options) then N1 (hostname)
DirkS
Fri Sep 21, 2018 6:26 pm
Curious.
It should also be in /etc/hosts (on the line with 127.0.1.1)
FTrevorGowen
Fri Sep 21, 2018 7:59 pm
Curious.
FWIW, as per the "old method" in my, out of date** (again) webpage here: http://www.cpmspectrepi.uk/raspberry_pi ... tName.html
Trev.
** but, indirectly, "corrected" (new method) here: http://www.cpmspectrepi.uk/raspberry_pi ... Tools.html
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Andyroo
Fri Sep 21, 2018 9:05 pm
The Pi Hut has a nice summary https://thepihut.com/blogs/raspberry-pi ... e-hostname for the command line jockeys.
Need Pi spray - these things are breeding in my house...
DirkS
Fri Sep 21, 2018 10:27 pm
unfortunately it's wrong...
It points to the line starting with 127.0.0..1 in /etc/hosts. That should be 127.0.1.1 as I stated above.
Andyroo
Fri Sep 21, 2018 10:39 pm
Thought that bug was fixed a long time ago going by https://bugs.debian.org/cgi-bin/bugrepo ... bug=316099
I know 127.0.0.1 works fine in MINT as that’s how the box upstairs is configured :D I don’t have a spare Pi to try at the moment though.
Return to “Beginners”
