Problems encountered when I tried to boot my Raspberry Pi
Posted: Sat Sep 15, 2018 12:59 am
Hi there, I am a beginner using RPI and try to build a computer vision + machine learning programs
but I encounter some problems with the system installation:
1) Version: Raspberry Pi Model 3 V1.2 2015
2) Installation method: NOOBS, following the direction on the Raspberry Pi official website
Problems encountered:
1) No display after it shows Raspbian has been installed
2) after I modify the config.txt and insert microSD again, does not show anything
Things I tried to debug the problem:
1) increase the current output from 1A to 2.4A, which should not be a problem for HDMI output right now
2) Modify the config.txt file and comment out these lines
hdmi_safe=1
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=82 # as I am using 1080p monitor with 60Hz output frequency
3) erase all the format and reinstall with NOOBS
Current Status:
Black screen all the time and not showing anything.
Previously I first tried to use Ubuntu core and it has a similar problem, is there anything else worth to try in order to get the system installed and work properly?
hdmi_safe=1
hdmi_group=2
Current Status:
