vajra11
Pushing data to MySQL using Pi
Mon Sep 10, 2018 7:16 am
I have a MySQL server installed on my window computer. I have tested connection between Pi and MySQL successfully with following program
import mysql.connector
db = mysql.connector.connect(user='database1', password='****',
                              host='192.168.0.111',
                              database='test3')
# Create a Cursor object to execute queries.
cur = db.cursor()
# Select data from table using SQL query.
cur.execute("SELECT * FROM tablename")
# print the first and second columns
for row in cur.fetchall() :
    print row[0], " ", row[1]
$ python dbtest1.py
1 Sample data
I have a MCP3008 ADC chip and raspberry Pi 3 I want to store data of sensor into MySQL database on my computer over the time.
How to set database connection to store sensor data into MySQL database in below program
# Simple example of reading the MCP3008 analog input channels and printing
# them all out.
# Author: Tony DiCola
# License: Public Domain
import time
import datetime
# Import SPI library (for hardware SPI) and MCP3008 library.
import Adafruit_GPIO.SPI as SPI
import Adafruit_MCP3008
# Software SPI configuration:
CLK  = 11
MISO = 9
MOSI = 10
CS   = 8
mcp = Adafruit_MCP3008.MCP3008(clk=CLK, cs=CS, miso=MISO, mosi=MOSI)
print(datetime.datetime.now())
# Hardware SPI configuration:
# SPI_PORT   = 0
# SPI_DEVICE = 0
# mcp = Adafruit_MCP3008.MCP3008(spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE))
print('Reading MCP3008 values, press Ctrl-C to quit...')
# Print nice channel column headers.
print('| {0:>4} | {1:>4} | {2:>4} | {3:>4} | {4:>4} | {5:>4} | {6:>4} | {7:>4} |'.format(*range(8)))
print('-' * 57)
# Main program loop.
while True:
    # Read all the ADC channel values in a list.
    values = [0]*8
    for i in range(8):
        # The read_adc function will get the value of the specified channel (0-7).
        values[i] = mcp.read_adc(i)
    # Print the ADC values.
    print('| {0:>4} | {1:>4} | {2:>4} | {3:>4} | {4:>4} | {5:>4} | {6:>4} | {7:>4} |'.format(*values))
    # Pause for half a second.
    time.sleep(0.5)
W. H. Heydt
Re: Pushing data to MySQL using Pi
Mon Sep 10, 2018 1:41 pm
The ID and password you are using to connect to the remote database has to have INSERT permission granted for the table in question. Then you build a string with all the values you need to write the table row. Call the database using the string you've built. Check for errors.
vajra11
Mon Sep 10, 2018 2:15 pm
I don't know much about Mysql program. I need help in Mysql program
| Field           | Type         | Null | Key | Default           | Extra |
| Data0           | varchar(50)  | NO   |     | NULL              |       |
| Data1           | varchar(50)  | NO   |     | NULL              |       |
| Data2           | varchar(50)  | NO   |     | NULL              |       |
| Data3           | varchar(50)  | NO   |     | NULL              |       |
| Data4           | varchar(50)  | NO   |     | NULL              |       |
| Data5           | varchar(50)  | NO   |     | NULL              |       |
| Data6           | varchar(50)  | NO   |     | NULL              |       |
| Data7           | varchar(50)  | NO   |     | NULL              |       |
import time
import datetime
import string
CLK  = 11
MISO = 9
MOSI = 10
CS   = 8
                              database='test3')
cur = db.cursor()
pfletch101
Mon Sep 10, 2018 3:34 pm
Then I am afraid that you need to spend some time learning at least the basics of database management with MySQL. I doubt that anyone here has the time or energy to tutor you. Googling "MySQL Introduction" produces a lot of worthwhile material.
vajra11
Tue Sep 11, 2018 6:16 pm
Hope now someone can help I checked table data isn't inserting into database
import time
import datetime
CLK  = 11
MISO = 9
MOSI = 10
CS   = 8
# SPI_PORT   = 0
# SPI_DEVICE = 0
db = mysql.connector.connect(user='db1', password='***',
                              host='192.168.0.108',
                              database='test3')
cur = db.cursor()
cur.execute('SELECT * from t1')
for row in cur:
    print('%r' % (row,))
print('-' * 57)
while True:
    values = [0]*8
    for i in range(8):
    time.sleep(0.5)
	cur.execute("""INSERT INTO t1(data1, data2, data3, data4, data5, data6, data7, data8)values(%s,%s,%s,%s,%s,%s,%s,%s)""",(values[0],values[1],values[2],values[3]),value[4],value[5],value[6],value[7])
    cur.execute('SELECT * FROM t1')
        time.sleep(10)
W. H. Heydt
Tue Sep 11, 2018 7:44 pm
import time
import datetime
CLK  = 11
MISO = 9
MOSI = 10
CS   = 8
# SPI_PORT   = 0
# SPI_DEVICE = 0
                              database='test3')
cur = db.cursor()
for row in cur:
print('-' * 57)
while True:
    values = [0]*8
    for i in range(8):
    time.sleep(0.5)
        time.sleep(10)
The first thing I would do is put some white space around the parameters and and a statement terminator (';') at the end, so that the string reads "INSERT INTO t1 (data1, data2, ...) values (%s, %s, ...);". The next thing I would do would be to check for returned errors. In C, that is done with:
   if(mysql_query(conn,q_string) != 0)
      print_dberr(conn,"Attendee Master insert failed");
      return;
The best thing to do, of course, since your insert *is* failing, is to capture the actual MySQL error message and print that rather than a message you have composed.
