DPaul
Shutdown at command level
Sun Sep 09, 2018 6:42 am
I am wondering if something i do is state-of-the art, although the app works perfectly.
Setup: a Rpi Zero W is designed to be a numeric keyboard witth a 3x4 matrix input keyboard.
Power comes from an USB connection and any data captured, is collected by a desktop program (via SSH)
On the Rpi runs a Python3 data capture program that also validates, etc...
This program runs continuously, UNTIL a "secret code" is typed on the matrix keyboard.
Then the python program executes the following statement, shutting down the Rpi completely.
os.system('sudo shutdown -h now')
Question:
This is kinda "brutal" . Should i not terminate the python program properly first? How can it terminate it's own execution?
But then i still need to somehow issue the shutdown statement (?).
Any thoughts on this ? Some equivalent of the old ".BAT' files in DOS : first terminate the program, then shut down the Rpi?
Yes , i could issue the commands from the desktop, but i would prefer to contain it in the Rpi.
thx,
Paul
rpdom
Re: Shutdown at command level
Sun Sep 09, 2018 7:31 am
The python program will be sent signals during the shutdown. The first is a "please close down now", if that doesn't work it gets sent a "end now!" request. If it still hasn't ended (which it should have done on the first request), it will just be terminated. There should be no need to do anything special, but you could possibly trap the first signal if you need to do some specific clean up.
DPaul
Sun Sep 09, 2018 7:55 am
thx, i realize that messages will be sent if i do it this way. But you say that does not matter.
After some searching i found 50% of another solution:
I could end my "While true : " loop with a "break" statement if the "secret code" is entered.
That would allow for a "finally:" with some cleanup statement.
But now i still have to shutdown the rpi altogether.
If i put that command as last "finally:" statement , it's a little cleaner, but it still may cause messages to be sent.
I feel that as long that the shutdown command is issued from the python program, it's not state of the art.
Or shouldn't i bother?
Paul
ghans
Sun Sep 09, 2018 9:11 am
Programs on Linux have default signal handlers. The Python interpreter is a program too !
Of course, Python being a full-fledged programming language allows you to override
the default signal handlers inside your own program itself.
If you want to it "correctly", overriding the SIGTERM handler of your very own program would be the way to do it.
The shutdown command is actually rather gentle. It tends to trigger SIGTERM handlers in all running programs sooner or later, which in itself should result in a orderly and clean shutdown.
ghans
Sun Sep 09, 2018 9:26 am
It's not difficult to add a SIGTERM handler.
https://stackoverflow.com/a/31464349
Test that with
python tester.py &
killall -s 15 tester.py
DPaul
Sun Sep 09, 2018 9:54 am
OK, thanks, this is what i found:
import signal
run = True
def handler_stop_signals(signum, frame):
global run
run = False
signal.signal(signal.SIGINT, handler_stop_signals)
signal.signal(signal.SIGTERM, handler_stop_signals)
while run:
pass # do stuff including other IO stuff
if i understand this correctly:....
instead of
finally:
GPIO.cleanup()
os.system('sudo shutdown -h')
i should do ...
finally:
GPIO.cleanup()
Paul
klricks
Sun Sep 09, 2018 2:43 pm
Question:
If you issue the shutdown -h without the 'now' then the system will delay shutdown for 1 min. This should give the program plenty of time to terminate before shutdown.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
PhilBr
Sun Sep 09, 2018 6:35 pm
It should all work if you simply close everything down (close files, reset GPIO, etc), issue the shutdown then
sys.exit(0)
That should terminate the program and be both simple and safe.
Phil
DPaul
Mon Sep 10, 2018 6:27 am
OK, thanks, plenty of possibilities.
My problemis solved !
Paul
Return to “Beginners”
