sayhello
switching psu 5 volt - which one to take?
Sun Aug 26, 2018 5:33 pm
dear community,
i need a switching psu 5 volt - which one to take?
saw some here:
https://www.banggood.com/search/switchi ... html?sbc=1
can you advice one!?
wh7qq
Re: switching psu 5 volt - which one to take?
Sun Aug 26, 2018 6:18 pm
Depends entirely on your intended use...RPi? Which model? Assuming RPi 3B+, 2.5 Amps at 5 Volts is required, especially if you plan to use USB accessories. Still, most of what was present on the web page you gave requires a higher DC voltage input...so they do not connect directly to the mains. If your need is for a mains powered RPi, there are lots from Adafruit, Sparkfun, PiHut and Amazon that are specifically built for the RPi and plug directly into a wall socket. So what are you going to do with it?
Brandon92
Sun Aug 26, 2018 6:21 pm
It is for his NAS.
edit
I think it it better to use for example this type and brand. Than you know that you power supply is good and wont damage something (especially in a NAS):
