ShiftPlusOne
Re: Is this still the procedure with 3 B + .......... ?
Wed Aug 22, 2018 3:27 pm
No, you shouldn't have to set the OTP bit and that vcgencmd will give you misleading results, since it's a different bit on the 3B+.
You should just be able to flash the latest version of Raspbian onto a USB device and boot off it.
bensimmo
Wed Aug 22, 2018 3:37 pm
The 3B+ should boot straight from a USB Image as is.
It is burried in here (search for MSD)
https://www.raspberrypi.org/blog/raspbe ... le-now-35/
k-pi
Re: Is this still the procedure to enable mass storage boot with 3 B + ?
Wed Aug 22, 2018 8:10 pm
Yes, only the 3B needs the bit setting, the 3B+ will boot from USB as it is. 8-)
hitsware
Wed Aug 22, 2018 9:05 pm
Thanks ,
I put my SDC in a USB adaptor and it worked like a charm !
I'll get a nice fresh stick for the " final " ( :lol: ) product ......
