torrik
measure height elevation
Mon Aug 20, 2018 4:16 pm
Is this possible to measure height elevation with a high accuracy with a RPi ?
I'm not looking for a pressure sensor that wouldn't provide sufficient accuracy. I want to be able to measure an elevation in the order of 1 or 2 cm.
What interests me is the relative height from point A to point B not the altitude
how do we get there?
Thanks for your help :)
thagrol
Re: measure height elevation
Mon Aug 20, 2018 6:07 pm
What sort of distances are you looking to measeure? And will you have a line of sight between points A and B?
For short distances with an unobstructed sight line you could use an ultra sound or laser based distamce sensor. Not sure what you'd use for long distances and/or without a clear sight line though.
Note to self: don't feed the trolls
If I've asked you a question, please answer it. I'm unlikely to be able to help without that information.
Mon Aug 20, 2018 6:23 pm
What sensor are you planning to use? GPS? Barometric?
Do you have datum elevation near to you like an airfield, airport or a hill with a trig point?
jbeale
Mon Aug 20, 2018 6:43 pm
There are pressure sensors that do have a few cm height resolution, for example, Honeywell makes this differential pressure sensor:
https://www.digikey.com/product-detail/ ... ND/3935154
its claimed *accuracy* is 0.25% full scale of 2.5 mbar, meaning 6.25 microbar or 625 mPa. At sea level & 15 C, that pressure change would be caused by a 5 cm elevation change. The resolution might be considerably better, depending on how long you wait to average the noise in readings.
Of course, a pressure sensor used as an altimeter is obviously affected by the weather- ambient barometric pressure is always changing, plus in practice there is always noise from wind, doors opening/closing, etc. which affects pressure readings at the few-cm level of sensitivity.
It is difficult to get cm-level height resolution from consumer-level GPS. For what it's worth, there are now $30 laser time-of-flight distance meters that have millimeter resolution over many 10s of meters. I have a Suaoki S9 and it does work as described. https://www.amazon.com/gp/product/B018FWF7X4
hippy
Mon Aug 20, 2018 6:55 pm
Are you saying the distance between one height and the other will be 1-2cm, or greater than that and you want to measure that to an accuracy of 1-2cm ?
W. H. Heydt
Mon Aug 20, 2018 11:37 pm
If I wanted to measure a height difference of that magnitude, I'd pull the 6 inch steel scale out of my pocket and do it directly.
As a practical matter, I would suggest reading up on the difference between "accuracy" and "precision".
