tony1812
Unable to fetch some archives
Sun Aug 19, 2018 3:06 pm
Hello, quit often when I update and grade my pi, I get error like this:
Last modification reported: Fri, 17 Aug 2018 16:40:06 +0000
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Why is that? Is there something wrong with the repository? Is there anything I can do to eliminate this error? Thanks.
DirkS
Re: Unable to fetch some archives
Sun Aug 19, 2018 3:22 pm
Did you do as suggested?
Run
sudo apt update
sudo apt upgrade
and if there are any errors post the *full* message here.
tony1812
Sun Aug 19, 2018 9:10 pm
yea sudo update
sudo upgrade
This is the entire error message
"Last modification reported: Fri, 17 Aug 2018 16:40:06 +0000
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?"
buja
Sun Aug 19, 2018 9:26 pm
I have the same problem the last couple of days.
Trying again later seems to work. How much later? Can be minutes or the next day.
DirkS
Sun Aug 19, 2018 10:47 pm
Odd... I would expect lines with the actual archives it is trying to read / download, etc...
Are you sure *all* the output consists of just those 2 lines?
tony1812
Sun Aug 19, 2018 11:56 pm
There are some other lines don't seem to be relevant, but theses two lines stick out.
tony1812
Sun Aug 19, 2018 11:59 pm
On and off, when I do update and upgrade, I had similar error messages in the past. I wonder if the problem exist on the repository? Perhaps it is managed by some newbies?
DirkS
Mon Aug 20, 2018 5:59 am
Well, it would be useful to see which repos you have problems with, but apparently you think otherwise.
Makes you think why you even bother to post the issue here...
Maybe you should report the problem to the maintainers of the repo(s) instead of this community-led forum.
