kokein
Shutdown command after Button press
Fri Aug 17, 2018 9:15 am
Can You help me, how to convert this code, to work with my RaPi 3B+ ?
I know that it's for ZeroPi and i cant make it work.
I want to make a simple python script, to ba able to shutdown my RaPi after pressing GPIO17 button (that is on my LCD)
And this is nice and simple in my opionion...
from gpiozero import Button
import os
Button(17).wait_for_press()
os.system("sudo halt")
But have no idea why there is such difference in Zero GPIO's commands, and RaPi3B+ type of importing buttons like:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(27, GPIO.IN)
All the best !
Nick
ElEscalador
Re: Shutdown command after Button press
Fri Aug 17, 2018 11:17 am
There is no difference in the code needed, it's just that the two examples are using different libraries to do the same thing (I don't know python too well, so I cannot speak for the code actually working). You could use different libraries or different languages... but if any work on a pi3 they would work on a zero and vice versa.
My Autonomous Robot Project and a few of my other projects below.
https://lloydbrombach.wordpress.com/
hippy
Fri Aug 17, 2018 12:48 pm
If it works on a Pi Zero then it should also work on a Pi 3B+. You will need the GPIO Zero library installed, but that may be included with the standard Raspbian distribution. So long as you connect to the GPIO on the 3B+ as you did on the Zero it should work.
When you say it doesn't work on the 3B+; what does it do, or not do, what error messages do you get ?
PeterO
Fri Aug 17, 2018 1:26 pm
It looks like OP thinks gpiozero can only be used on a PiZero ! Which is understandable and shows the poor choice of library names !
PeterO
davidcoton
Fri Aug 17, 2018 2:06 pm
PeterO
FTFY (because I couldn't parse it first time).
@kokein: Try the same code that works on the zero (using gpiozero library) on the Pi3B+. It should just work, as stated above gpiozero works on all current Pi models.
Signature retired
PeterO
Fri Aug 17, 2018 3:21 pm
You should have seen it before I fixed (some of) the typos. My "space bar thumbs" are often a bit to quick !
PeterO
kokein
Wed Aug 22, 2018 8:16 am
Thank You all for support !
In deed, i thougt that "zero" is for "ZeroPi" - and now i know that is only library :) that work on RaPi3B+ (also)
Thats great, becaose i found verry nice code do controll my GPIO buttons - and its more easy then RPi.GPIO as GPIO
Too bad that its not nice explained - and most of all tutorials go to "RPi.GPIO as GPIO".
I think i can share it for other beginers ;)
https://github.com/scruss/shutdown_button
And one more link with more infos and pictures: http://scruss.com/blog/2017/10/21/combi ... pberry-pi/
All the best !
Nick
