gabriel.rosseel
Update VNC Server
Fri Aug 17, 2018 7:45 am
When I contact my Raspberry PI trought my VNC Viewer on my Windows workstation I see in VNC Server - Information Center: "VNC Connect 6.3.1 is available"
I also run Webmin on my Windows workstation and Webmin says "All installed packages are up to date"
I seem to remember that there was a few years ago a simular topic on this forum but I can't find it anymore.
Can anyone help me how I can update my raspberry so I run the latest VNC server version 6.3.1?
Is it normal that Webmin doesn't see there is an update of VNC Connect avaiable?
As OS i run Jessie (Debian Linux 9.4).
Thanks in in advance, gabriël
Re: Update VNC Server
Fri Aug 17, 2018 8:09 am
Confused as Raspbian Jessie is 8.x and Raspbian Stretch is 9.x....
adieu
My other Computer is an Asus CS10 ChromeBit
DirkS
Fri Aug 17, 2018 8:21 am
Does webmin know if there are updates in the repository?
The information in the VNC dialog comes from the RealVNC website, not from the repository from where you install packages.
Which version is installed? Check in the RealVNC GUI dialog or use 'apt-cache policy realvnc-vnc-server' from the command line?
Current version is 6.3.1.36657
It could be that vnc is just a bit 'confused': see https://www.raspberrypi.org/forums/view ... c#p1352719
gabriel.rosseel
Fri Aug 17, 2018 9:05 am
my mistake: my os is stretch, not jessie
the command apt-cache policy realvnc-vnc-server says I am running version 6.2.0.29523
Fri Aug 17, 2018 9:09 am
Not up to date Raspbian Stretch ?
sudo apt update
sudo apt full-upgrade
adieu
gabriel.rosseel
Fri Aug 17, 2018 10:54 am
I executed the 2 commands bur VNC Connect wasn't updated
DirkS
Fri Aug 17, 2018 11:18 am
Do you see any error messages?
Please post full output of both commands
gabriel.rosseel
Fri Aug 17, 2018 1:00 pm
sudo apt update
Hit:1 http://archive.raspberrypi.org/debian jessie InRelease
Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Ign:3 http://download.webmin.com/download/repository sarge InRelease
Hit:4 http://download.webmin.com/download/repository sarge Release
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: Target Packages (contrib/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:5
W: Target Packages (contrib/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:5
W: Target Translations (contrib/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:5
W: Target Translations (contrib/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:4 and /etc/apt/sources.list:5
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
DirkS
Fri Aug 17, 2018 1:11 pm
Did you upgrade from Jessie to Stretch?
You forgot to change the reference to Jessie in /etc/apt/sources.list.d/raspi.list, so the upgrade was probably not complete.
Edit that and run the commands that @FotL listed a few posts further up.
Don't be surprised if your desktop and other GUI elements start to look different...
You may also need to install a few packages that were new in Stretch.
gabriel.rosseel
Fri Aug 17, 2018 2:18 pm
I changed the references from jessie to strech in the file /etc/apt/sources.list.d/raspi.list as you suggested.
forgive me but I can't find te ref to @FotL (still a beginner).
Is it all right if a execute the commands "sudo apt-get update " and "sudo apt full upgrade" ?
in the meanwhile I will make an image of my SD-card.
Fri Aug 17, 2018 3:07 pm
FotL (fruit of the loom) is reference my post above..... ie
sudo apt update
adieu
gabriel.rosseel
Fri Aug 17, 2018 4:10 pm
it works !!
I executed the 2 commands, rebooted and everyhing is now updated.
Thank you very much for all the help.
gabriël
