david_1234
using PI with 2 serail ports?
Mon Aug 06, 2018 2:39 pm
Hello ,
wanted to know
I want to be able to read data from 2 serail devices at the same time
does the PI have this option?
open 2 serail ports at the same time ? or does it have only 1 ?
Thanks ,
DirkS
Re: using PI with 2 serail ports?
Mon Aug 06, 2018 3:06 pm
On the standard Pi you can use 1 onboard UART at a time.
You *can* add USB serial devices.
scotty101
Mon Aug 06, 2018 3:09 pm
The SoC on the Pi has two UARTs however only 1 is available for general use.
(Insert lots of complex stuff about the other being used by the Bluetooth/Wifi that you probably don't care about)
You can however add a USB to UART converter or use a SPI/I2C UART to give you an extra port.
PiGraham
Mon Aug 06, 2018 4:26 pm
USB serial interfaces are cheap and effective to I'd go that way, but DMA controlled software serial on any gpio pin is another option.
viewtopic.php?t=35544#p446164
http://abyz.me.uk/rpi/pigpio/cif.html#gpioWaveAddSerial
