unknowntothem
Recording micro-seconds for more than 1 second
Thu Jul 26, 2018 6:40 am
Hello All,
Apologies, I guess this is more of a python question but it's for my first raspberry pi project so hope that someone can advise.
I am reading 4 sensors at 600 micro-seconds per sample. At the same time I am adding a timestamp to each sample. I have used the following code which times 999 999 micro-seconds then resets. Does anyone know how to extend this timer to 60 seconds (i.e. 60 999 999)? Any advise would be appreciated. I've only added the important code below, will add full code if required.
from datetime import datetime
while True:
	now = datetime.now()
	print(now.microsecond)
joan
Re: Recording micro-seconds for more than 1 second
Thu Jul 26, 2018 9:36 am
Why not use the time() method from module time?
That returns the number of microseconds since the Unix epoch.
import time
now = time.time()
lmarmisa
Thu Jul 26, 2018 11:20 am
Try this code:
from datetime import datetime, date, time
while True:
	usec = now.second * 1000000 + now.microsecond
	print(usec)
If you prefer to get an string, try this alternative:
usec = "%02d%06d" %(now.second, now.microsecond)
NOTE: the range will be from 00000000 to 59999999.
davidcoton
Thu Jul 26, 2018 8:19 pm
import time
now = time.time()
+1 for Joan's idea. Use the proper tool for the job, so that you:
  1. Avoid problems caused by the potentially variable start time within the second and minute, and therefore with the value of the time returning to zero during your sampling.
  2. Future proof your code so that you can change the overall timer period without issues.
  3. Write code that can be re-used in similar but different projects.
Signature retired
unknowntothem
Re: Recording micro-seconds for more than 1 second [SOLVED]
Mon Jul 30, 2018 1:02 pm
Hello All,
Thank you very much for the responses, all of the ideas worked. I ended up using lmarmisa's option. just because I didn't lose any sampling speed and the output format was suitable with my current MATLab code.
