sumanth
Raspberry Pi not connecting with Brick Pi
Thu Jul 19, 2018 6:47 am
I am using Raspberry Pi 3 Model B+ and a BrickPi board. I have also modified installed Raspbian OS by following the steps mentioned in https://www.dexterindustries.com/BrickP ... d/pi-prep/
After this step, I have connected the motor and tried to test the motor by running the motor_sensor.py
The following error is coming up:
[email protected]:~ $ python motor_sensor.py
File "motor_sensor.py", line 7, in <module>
BrickPiSetupSensors()
File "build/bdist.linux-armv7l/egg/BrickPi.py", line 492,
in BrickPiSetupSensors
File "build/bdist.linux-armv7l/egg/BrickPi.py", line 698,
in BrickPiFlush
File "/usr/lib/python2.7/dist-packages/serial/serialutil.py",
line 572, in inWaiting
return self.in_waiting
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py",
line 456, in in_waiting
s = fcntl.ioctl(self.fd, TIOCINQ, TIOCM_zero_str)
IOError: [Errno 25] Inappropriate ioctl for device
motor_sensor.py script is as follows:
from BrickPi import *
BrickPiSetup()
BrickPi.MotorEnable[PORT_A] = 1
BrickPi.MotorSpeed[PORT_A] = 200
BrickPiUpdateValues()
I asked this question and I got a reply from Dexter Industries Engineer saying that
"The original BrickPi and the BrickPi+ are not supported on Raspbian Stretch. You will need to use an older version of Raspbian, such as Jessie or Wheezy.
From your description and output message, it seems like an issue with the RPi software, not the BrickPi firmware"
How can I switch to Raspbian Jessie or Wheezy from Stretch and is it recommendable??
The Traveler
Re: Raspberry Pi not connecting with Brick Pi
Thu Jul 19, 2018 12:50 pm
If it solves your problem simply burn an SD card with an older versions and use it. Otherwise, it appears your out of luck unless the Dexter Industries people want to update their software to work with Stretch.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
pcmanbob
Thu Jul 19, 2018 2:24 pm
Your problem now becomes Jessie does not support the pi 3B+ because it does not have the correct files to support the new networking on the pi 3B+.
It can be made to work I believe but you would need a pi 3B or a pi 2B to be able to update the OS before putting the SD card in the pi 3B+.
if you search this forum to should find details on how to do it.
Thu Jul 19, 2018 3:53 pm
Since all the code is available at: https://github.com/DexterInd/BrickPi you may be able to hack that and get it working on Stretch. Then send your changes back as a pull request.
One thing that sticks out is the serial devices changed. So this line in BrickPi.py may need a tweak
ser.port='/dev/ttyAMA0'
This is a doctor free zone.
