Hello
Is their a specific procedure to shutting down the Pi other then log out and then power off system. Should something else be done to save files or other.??
Thank you
Scott
sudo haltThank you billb for the quick responsebillb wrote:On the terminal:
sudo halt
Right -- you'll see the shutdown procedure going past and the screen will go blank, leaving only the red power led on the Pi -- then you can turn off the power.scottnichols wrote:So it goes like this log out then input sudo hault at the prompt then I can power off correct?
erm no.billb wrote:Right -- you'll see the shutdown procedure going past and the screen will go blank, leaving only the red power led on the Pi -- then you can turn off the power.scottnichols wrote:So it goes like this log out then input sudo hault at the prompt then I can power off correct?
I think he meant log out of LXDE, but I may be wrong.SN wrote:erm no.billb wrote:Right -- you'll see the shutdown procedure going past and the screen will go blank, leaving only the red power led on the Pi -- then you can turn off the power.scottnichols wrote:So it goes like this log out then input sudo hault at the prompt then I can power off correct?
you can't do a sudo halt if you're not logged in
so when you're ready to shut down your pi, either from the console or remotely logged in over ssh/putty on a logged in session, then you type sudo halt <RETURN>
and you will be logged out a split second after you see some kind of shutdown message
Let's hope so.alexeames wrote:I think he meant log out of LXDE
