Fri Nov 02, 2012 10:36 pm
Speaking of alternative ways of powering the Pi...
I recently tested this (see below) hookup - and it seems to work fine. What I am curious about is suggestions for how to test it more thoroughly. As I say, it seems to work fine, but I'm not sure if I have exercised it well enough to be confident of that.
The hookup is:
1) Pi: Latest version - with 512M and latest firmware.
2) Powered USB hub, which is actually USB connected to another PC laying around here. I.e., I am not using it as a USB hub in connection with the Pi. I'm only using it as a power source.
3) USB A male to micro-USB male cable (from a Kindle - used to charge the Kindle from a PC). I connect the USB A end to the powered hub and the micro-USB end to the Pi (and it boots right up).
4) No keyboard/mouse/video connected to the Pi. Access is by ssh.
I ssh in and everything looks fine. I transferred a 10M file to a remote host - that was fine. My understanding is that, in fact, the ethernet is the biggest power hog of all the components (about 230mA) so I figure exercising the ethernet is a good test.
Any other tests I should be running?
