To check the status of relay using interrupt in raspberry pi
Posted: Tue Jul 10, 2018 5:32 am
by Muhsina
Hi, I am working with a raspberry pi with a relay with the incandescent bulb, buzzer, and button via SSH. The code is in a way that when I press a key from the keyboard the bulb and buzzer should be ON and when I press button both should get OFF. But my button code is not working properly.
And also I want to check the status of the relay using the interrupt and whenever the light on it should be sent a message to the database. But I don't know with interrupts. Below is my code. Please help me. Thanks in advance
import RPi.GPIO as GPIO
import time
in1 = 25 #GPIO25 pin22
buzzer=24 #GPIO24 PIN18
led=8 #GPIO8 PIN24
button=23 #GPIO23 PIN 16
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(in1, GPIO.OUT)
GPIO.setup(buzzer,GPIO.OUT)
GPIO.setup(led,GPIO.OUT)
        #GPIO.setup(button,GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.output(in1, False)
GPIO.output(buzzer,False)
GPIO.output(led,False)
try:
        GPIO.output(in1,False)
        while True:
# check from database whether it is effective or deffective .currently I have inputted from keyboard
                variable=raw_input()
                if variable=="a":
                        m=variable
                        for x in m:
                                GPIO.output(in1, True)
                                time.sleep(0.05)
                                time.sleep(0.05)
                        GPIO.output(buzzer,True)
                        GPIO.output(led,True)
                        if in1==True || buzzer==True:
                                print "messge to database:pending"
                #def my_callback(channel):
                #if GPIO.input(button) == True:
                GPIO.wait_for_edge(button, GPIO.FALLING)
                #if variable=="b":
                        #while 1:
                print "mesage to database:ack completed"
                        #else:
                                #pass
                #else:
                        #pass
except:
        GPIO.cleanup()
If there is any error in my code please help me to rectify that. Thanks
Re: To check the status of relay using interrupt in raspberry pi
Posted: Tue Jul 10, 2018 6:43 am
by Z80 Refugee
Are you sure it isn't your button that is not working properly? Beginners Guide to Wiring Things to the GPIO
I don't think that's a very good idea. The purpose of a relay is to adapt the RPi's weak output drive capability to a high power load and to isolate the potentially damaging power from getting back to the RPi. In order to "check the status" of the relay, you would need to connect the relay's output back to the RPi (probably via an opto-isolator, depending on what the relay is actually driving). You already know what the status of the relay should be - it's responding to the RPi output. I assume you are looking for fault monitoring, in which case you should be checking the status of the driven load and not just the relay output. The problem with fault monitoring is that it can more than double your circuitry, and then you need something to check your fault monitoring circuit...
However, that said, it is easy enough if the relay has a spare pair of contacts, which can be used as a dedicated switch input to the RPi. That will confirm the relay has switched, but tell you nothing about the load circuit.
You don't need interrupts either - interrupts should be reserved for events which occur unpredictably and must be acted on as soon as possible. With a suitable status circuit wired to an input pin, read the pin periodically in the main loop of your program instead of using an interrupt.
