sayhello
does this display fit to Raspi - does it work with Raspi
Wed Jul 04, 2018 4:07 pm
one question regarding a Display: ps -
see this Display : LCD-Modul DISPLAYTECH DT043BTFT-TS, 4,3", 480x272, Touch
10,9 cm TFT Touchscreen-Display mit integriertem Controller, LED-Hintergrundbeleuchtung und 24-bit Interface. Der Anschluss erfolgt über einen 45-poligen FPC-Connector (passende Buchse siehe Art.Nr. 451 752).
see the link https://www.pollin.de/p/lcd-modul-displ ... uch-120971
well does this fit to Raspi!?
love to hear from you
The Traveler
Re: does this display fit to Raspi - does it work with Raspi
Wed Jul 04, 2018 4:19 pm
Offhand, after looking at the data sheet, I'd say "only with a lot of work" and even then, maybe not. You need the hardware controller interface and device drivers at the least.
Cheers.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
sayhello
Thu Jul 05, 2018 6:18 am
hello again
many many thanks for your quick answer and all your hints.
greetings
sayhello
