as1mov48
under voltage error
Wed Jun 13, 2018 11:06 am
I'm running my Pi3 with a 5v 2A power supply from a 32Gb Class 10 samsung SD card, Flashed withe Raspbian, but I get an 'under voltage error whenever I boot up or put a flash drive in an USB slot.
Any Ideas? should I get a higher amperage PS?
Re: under voltage error
Wed Jun 13, 2018 11:30 am
PS should be just about OK (The official PS is 2.5A), but the cable may well be a bit rubbish. Always worth getting a decent specified cable - makes a huge difference.
LTolledo
Wed Jun 13, 2018 2:15 pm
Get a micro USB cable set that is rated 2A or above. Make sure its a charging cable not a data transfer cable
Charging cables tend to have bigger 2-conductor cables
Data transfer cables tend to have smaller 4-conductor cables
If you like DIY you can make your own, just more expensive and time consuming...
or better yet get a 5V 2.5A mircoUSB power supply set. Plug and play... finished
I power up my 32GB microSD bootable RPi3B, fan-cooled, WiFi connected, bluetooth enabled, with I2S DAC HAT, 2.5GHz unifying dongle (for keyboard and mouse), and powering a small 5-LED desk lamp, on just a 5V 2.5A power supply set. Dont even see the "Flash" insignia whenever I insert and access a USB thumbdrive...
Some people be like:
