Hello ,
I enabled uart port of rpi using the below link and it was working fine in 9600 baud rate.
https://community.particle.io/t/tutoria ... pi-3/30194
I used the below line to initialize the uart port in 9600 baud rate
int fd = serialOpen("/dev/ttyS0",9600);
I am using Uart to get GPS data from the GPS sensor. This is working fine.
I need to increase the baud rate to 921600. I set the baud rate of the GPS to 921600 and I cant figure out a way to increase the baud rate in Raspberry pi end. can you tell me how to increase the baud rate of uart in RPI??
