dennis.knight
X11VNC install error
Tue Jun 12, 2018 10:22 pm
I have a clean install on PI 3+
I am trying to install x11vnc and get this:
[email protected]:~ $ sudo apt-get clean
[email protected]:~ $ sudo apt-get install x11vnc
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
libvncclient0 libvncserver0 tcl tcl8.6 tk tk8.6 x11vnc-data
Suggested packages:
tcl-tclreadline
The following NEW packages will be installed:
libvncclient0 libvncserver0 tcl tcl8.6 tk tk8.6 x11vnc x11vnc-data
0 upgraded, 8 newly installed, 0 to remove and 11 not upgraded.
Need to get 1,621 kB of archives.
After this operation, 3,407 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvncclient0 armhf 0.9.9+dfsg2-6.1+deb8u2
404 Not Found [IP: 93.93.128.193 80]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libvncserver0 armhf 0.9.9+dfsg2-6.1+deb8u2
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main tcl8.6 armhf 8.6.2+dfsg-2 [122 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main tcl armhf 8.6.0+8+b1 [5,508 B]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main tk8.6 armhf 8.6.2-1 [71.0 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main tk armhf 8.6.0+8+b1 [5,534 B]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main x11vnc-data all 0.9.13-1.2 [215 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main x11vnc armhf 0.9.13-1.2 [910 kB]
Fetched 1,329 kB in 8s (165 kB/s)
E: Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
What am I doing wrong?
Dennis
DirkS
Re: X11VNC install error
Wed Jun 13, 2018 9:15 am
Most likely you forgot to update the list with available packages
sudo apt-get update
before trying to install the program
A quick check confirms that current version is of these files is 'deb8u3' but apt-get requests 'deb8u2'
davidcoton
Wed Jun 13, 2018 7:08 pm
Suggested packages:
tcl-tclreadline
Dennis
Something very odd there. You say you have a "clean install" yet the repositories are set to Jessie, which doesn't (without some messing around) support the Pi 3B+.
So just to check, you say "Pi 3+", is that actually Pi 3B+ or something else?
A "clean install" of Raspbian for a Pi 3B+ will mean a new download of the latest version of Raspbian.
Then also, as above, always use
sudo apt update
before other apt install or upgrade operations (apt is a newer alternative to apt-get, and is preferred for direct command-line use).
Note that the error messages even suggest that.
"Thanks for saving my life." See https://www.raspberrypi.org/forums/viewtopic.php?p=1327656#p1327656
“Raspberry Pi is a trademark of the Raspberry Pi Foundation”
