makem
Is CPU usage above 100% really possible?
Tue Jun 12, 2018 3:49 pm
Wow, %age CPU:
[email protected]:~$ /opt/vc/bin/vcgencmd measure_temp
temp=40.8'C
Re: Is this really possible?
Tue Jun 12, 2018 4:09 pm
Yes (sadly). The Pi has four cores, each of which can run up to 100%. Four cores running at 100% makes top display 400%...
makem
Tue Jun 12, 2018 4:39 pm
Why sadly?
Wed Jun 13, 2018 11:35 am
Why sadly?
Because you had the ask the question - it's just a confusing way of looking at it.
fanoush
Re: Is CPU usage above 100% really possible?
Wed Jun 13, 2018 12:19 pm
Well, the other way is also a bit confusing. I often see in windows task manager something eating 12% CPU and it is is not so clear at first sight this is single threaded cpu bound process using 1 of 8 cores at 100%. With cpu usage so low one would guess the process is sleeping or doing some i/o but if fact the CPU is the bottleneck.
makem
Wed Jun 13, 2018 2:36 pm
Why sadly?
Yes, agreed. The 'correct' %age usage is in the top left hand corner so I cannot see why this is repeated on a total core usage basis unless it stated core1 @ %, core2 @ % etc. because a total % of 1 to 4 does not seem useful, not to me anyway.
Actually it raises a question, is the load spread evenly over all cores or does it spread across them as each core reaches a predetermined %age?
jahboater
Wed Jun 13, 2018 3:18 pm
Probably the former.
CPU usage is always 100% :)
That is, the CPU is either executing instructions or idle, nothing in between.
50% utilization is in fact 100% of the CPU for 50% of the time.
Apart from that, multiple processes sharing a CPU with time division multiplexing are constantly having to context switch. If they were spread across all the CPU's there would be less overhead.
There used to be a task that distributed interrupts evenly across the CPU's.
makem
Wed Jun 13, 2018 6:05 pm
So, for each 'job' the processor(1, 2, 3 or 4), works flat out for 50% of the time the job takes to complete? That's strange, so I wait for 50% of the time while nothing is happening for the 'job' to complete?
I don't think so. I believe the 'job' starts and the %age of the processor's usage increases or decreases as necessary to complete the 'job' in the shortest possible time.
FTrevorGowen
Wed Jun 13, 2018 6:29 pm
I suspect (historically**, maybe) that job priority (niceness?) may also play a part.
Trev.
** Assuming "niceness" works along similar lines to the JCL methods of "ye olde mainframes" when you had to pay for computer (processing) time. :-)
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
jahboater
Wed Jun 13, 2018 6:37 pm
I meant the CPU can either be executing an instruction, or it is idle (or sleeping on x86). It cant "half" be executing an instruction, it either is or it isn't :)
Tools like top record the percentage of time within the measurement interval that the CPU was actually executing instructions.
jahboater
Wed Jun 13, 2018 6:45 pm
Trev.
Yes thats right. Although its upside down! Reducing nice increases effective priority,
When the clock interrupt occurs it probably just takes the runnable process with the highest priority.
UNIX had the rather clever idea, compared to other OS's of the day, that the priority was inversely proportional to the CPU time used in the last interval. Thus someone typing at a keyboard using little CPU would get good interactive response, but a CPU intensive batch job would get lower priority and run in the background (and round robin with the other big jobs). And so on. Very clever in that it solved 99% of the problems with one trivial equation. Niceness just adds an offset to that calculation.
Thu Jun 14, 2018 8:55 am
With top press the [1] key and you get the CPU broken down by core.
This is a hippy & doctor free zone.
mfa298
Thu Jun 14, 2018 10:47 am
The complete answer there probably gets more complex.
A single process/thread can only run on a single core at a time*. Luckily most applications these days run in multiple processes/threads and you have more than one thing running on a system at a time. This means the load usually gets spread over the multiple cores sensibly (If you had a bunch of background processes and one single threaded cpu bound application then you might find one core is running at 100% when the others are only at 5%).
* in the early days of multicore machines some things (usually games or other specialised applications) were heavily optimised to run really well in a single thread. So for some tasks a single core 3GHz machine was preferable to a dual core 2GHz machine.
