natetallent
rpi3 gpio speakers
Wed Jun 06, 2018 9:15 pm
i want sound but every other post basically refers to a separate unit for a speaker or solutions for nothing but buzzers/beepers. i dont care about sound quality necessarily and i just want out of the way crappy speakers for gaming videos and stuff like that. i found this on amazon and i was wondering if there was a way to some how connect them to the gpio and
https://www.amazon.com/uxcell-Metal-Int ... 5T373W3X2
if these arent a good option can someone please give me a suggestion or two
i have a rpi3b in a smart pi touch case and the official rpi 7 inch touchscreen with a usb battery pack that supplies enough power (5v 3a)
klricks
Re: rpi3 gpio speakers
Thu Jun 07, 2018 12:30 am
The speakers cannot be connected directly to any GPIO. The RPi has audio output available in the 4 pole TRRS jack. You also need an audio amplifier to power the speakers though you can probably hear something in a quiet room without an amp. I would suggest to get a cheap powered computer speakers and be done with it. A 3 pole stereo 3.5mm plug found on most speaker sets can be used in the 4 pole jack on the RPi without any problem. Another option is to get USB powered speakers which draw power for the amp from the USB, but audio is fed by a 3.5mm jack. (Not USB sound card).
gkaiseril
Thu Jun 07, 2018 2:36 am
There are add on boards and software that use the GPIO pins to convert the digital signal to mono or stereo.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
Imperf3kt
Thu Jun 07, 2018 3:17 am
For what possible purpose? There is already an audio out jack on a Pi3 of the same quality as those add on boards
55:55:44:44:4C
52:4C:52:42:41
Thu Jun 07, 2018 5:30 am
I2S audio is much higher quality than that which is available on the jack socket.
LTolledo
Fri Jun 08, 2018 3:51 am
to be able to use your $9 speakers... first you need a good DIY encolsure...then...
1. get the Pimoroni pHAT Beat, insert to your RPi's GPIO, attach speakers to the pHat Beat, load drivers, done.
2. get USB sound card and insert to USB port, get DIY amp (PAM8403 or better) with enclosures and accessories, get connecting cables and connect, done.
if you're a DIY kind of guy you'll probably go for #2. May cost more ($$$ and time) but fun along the way, I know the feeling, I've been there.
Honestly, just ditch the speakers, and get a USB sound card ($7) and a USB powered speakers ($13) from Amazon and enjoy immediately.
The choice is still yours to make...
Some people be like:
Imperf3kt
Fri Jun 08, 2018 5:30 am
My mistake. I thought they were talking about pushing the analogue audio through PWM.
55:55:44:44:4C
52:4C:52:42:41
MarkDH102
Fri Jun 08, 2018 6:10 am
I use this :
https://shop.pimoroni.com/products/speaker-phat
Not brilliant sound quality, but fairly cheap and a reasonably good volume. Mono though if that's an issue. I use it for speech rather than music.
natetallent
Sat Jun 09, 2018 12:27 am
I use this :
this looks useful but the screen i have takes up two of the gpio pins for power
natetallent
Sat Jun 09, 2018 12:32 am
i am trying to make this as compact and portable as possible. could you tell me where that 4 pole thingy is? i would love to try that if it means it small(ish). im sort of a noob to rpi hardware related stuff.
klricks
Sat Jun 09, 2018 1:46 am
It is near the HDMI port and looks like a 'headphone' jack.
hippy
Sat Jun 09, 2018 10:57 am
It should be possible to connect a piezo or speaker with a simple single transistor driver direct to a digital GPIO line and generate sound, audio and speech through that. It is just a case of bashing the right pulse train through that.
That's how Windows allowed sound to be produced from a motherboard piezo way back to Windows 3.1 and many microcontroller projects have copied that. It's not going to be great sound but for all it requires it is pretty good and cheap too.
One can also improve on the 'just a piezo' scheme. Roman Black did a fair amount of work on bit-banged audio generation for the PICmicro -
https://www.romanblack.com/BTc_alg.htm
I also like the projects which just pump UART serial straight to a speaker.
It is easy enough to bit-bang tones and tunes out of a Raspberry Pi but I don't know if anyone has created a full bit-banged audio driver or application.
Having the Pi be able to generate audio via HDMI, analogue and digital GPIO lines would be useful to have. Windows 3.1 could do it so I am sure Linux could also.
Sat Jun 09, 2018 11:03 am
The RPi Zero has no audio out, but as the GPIO is the same across RPis maybe:
https://learn.adafruit.com/introducing- ... io-outputs
pksato
Sat Jun 09, 2018 11:51 am
In addition to the speaker you will need a power amplifier, like PAM8403 module (search on you favorite electronic gadget store).
It is a small class D audio amplifier.
And a TRRS plug (old/cheap smartphone earphone/mic cable). Or solder wires direct to pads of A/V jack.
LTolledo
Sat Jun 09, 2018 12:41 pm
Add a GPIO expander shield
https://www.ebay.com/itm/GPIO-Expansion ... 2024221005
to the list....
