devyani_13
external power supply
Thu May 31, 2018 11:07 am
i am using raspberry pi3 b+ now i want to power up my pi through GPIO pin 2 or 4 using LM2576,and it should also work with usb power supply from adapter. i want to know winch supply is currently used by pi,if both supplies are present i want to use only power from the LM2576
Imperf3kt
Re: external power supply
Thu May 31, 2018 2:05 pm
Only ever connect one at a time. The Pi has no way of differentiating the two supplies and using both at the same time will damage one or both of your power supplies.
55:55:44:44:4C
52:4C:52:42:41
Rose coloured glasses are difficult to see through.
drgeoff
Thu May 31, 2018 2:40 pm
It is good advice to only connect one power source at a time though the risk of damage to one or both is actually quite low.
pksato
Fri Jun 01, 2018 5:43 pm
Didoes can be used switch between two or more power sources.
Each power source have a diode in series.
The main power need voltage little bit high that others.
Use Schottky diodes (1N5820) with low voltage drop.
