vinylash
SD card overclock query
Wed May 23, 2018 12:49 am
Hi there. So I've been playing around with my pi3b+ and got some pretty good results with overclocking. But the last thing I'd like to tweak is the SD card speed. I've been reading online about the line added to config.txt to get it working but the bit I'm a little confused about, is to get a full 100mz the core has to be set to specific speed. I tried adding the line to config.txt and querying the speed with the command on the retropie wiki, but I'm only getting about 83mhz. I'm using a Samsung Evo+ card, so I'm confident it will take the tweak. I'm running
Arm at 1450 overvolt 4
Core 515
Ram 500 overvolt 2.
What would I need to set the core to get 100mhz out of the SD card?
Thanks in a advance.
Re: SD card overclock query
Wed May 23, 2018 7:53 am
Core 515
Ram 500 overvolt 2.
https://www.jeffgeerling.com/blog/2016/ ... berry-pi-3
adieu
My other Computer is an Asus CS10 ChromeBit
hommar
Wed May 23, 2018 10:11 am
viewtopic.php?f=63&t=199414&p=1244421#p1244181
You have "EVO Plus" or "EVO+"?
boyoh
Wed May 23, 2018 3:15 pm
Why is it soon as somebody gets a RaspberryPi, They want to start over clocking it
It is like buying a Ford and tweaking to run like a F1 Race car, It is at peek signal
change, that more current is drawn from the power supply, this is very high for long
periods, if playing games,,Heat sinks help, but other components will be under
stress.
Regards BoyOh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
Return to “Beginners”
