WiVM
Powering the screen with expansion board
Wed May 16, 2018 9:09 am
I am using a PI 3 model B+ with and Sparkfun explorer USB module to connect a XBee-PRO S2C 2.4GHz transceiver with a 2.5A power supply. I now want to connect the standard Raspberry 7 inch display to the PI, but the first 26 pins are used by a GPS expansion board. How should I connect this display and will the one power supply be sufficient?
I noticed that the display also has a USB power socket. Should or can I connect that with a separate power supply (with I don't prefer) and insert the data cable in the PI. Or is there an other way to interconnect those apart from the power pins used by the expansion board?
Thank you
Who is online
Users browsing this forum: bertlea and 58 guests
