dizzo
USB Booting Question
Mon May 14, 2018 12:37 am
I've searched through the topics and I can't seem to find a simply answer to this issue. If someone knows a thread that answers it please direct me.
I have a Model 3b+ with a powered 1TB external HDD attached. I'd like to have the pi boot from that drive since my understanding is that it will give better performance
I used the SD Card Copier to copy my SD card over to the HDD, that seems to have worked fine. I see the exact same partitions with at 900+ GB "data" partition.
As far as I can tell the pi is still booting from the SD card, which makes sense given the boot order the pi generally operates from.
So my ultimate question is; what do I do to erase Raspbian from the SD card safely without also deleting the stuff (the bootloader I think) that still needs to be on the SD card.
Thanks.
Re: USB Booting Question
Mon May 14, 2018 8:25 am
With the 3B+ you shouldn't need the SD card at all. There will be a few seconds delay while the Pi checks to see if there is a valid SD card, before moving on to boot from the USB device.
W. H. Heydt
Mon May 14, 2018 2:29 pm
Shut down the Pi. Remove the SD card. Restart the Pi. That's it.
piglet
Mon May 14, 2018 2:38 pm
I never got this to work reliably on a 3B with a WD Foundation Edition Pi drive. Maybe 1 time out of 10. Are things fundamentally different on a 3B+? I ended up having to use a small SD card just to get reliable booting.
Mon May 14, 2018 3:02 pm
Yes, the 3B+ has some improvements in the boot ROM that support more devices. I couldn't get a 3B to boot from my USB disk, but it worked first time on a 3B+
k-pi
Mon May 14, 2018 3:33 pm
I've been booting my 3Bs & 3B+ from pendrives & external disks (as long as they get enough power) without any problems, :)
HawaiianPi
Mon May 14, 2018 6:00 pm
The main issue with mechanical hard drives is the spin-up time. The Pi boot loader waits 2 seconds for the drive to get ready, and if it takes longer than that it won't be seen and boot will fail. Having only the bootcode.bin file on a FAT32 SD card with another file named "timeout" will increase the wait time and possibly fix the problem.
If you want pure, no SD card boot, and you suspect a wait time issue, then adding "program_usb_boot_timeout=1" to config.txt on a Raspbain SD card and booting it once will set an OTP bit that tells the system to wait 5 seconds. Note this is different from the OTP bit that enables USB boot, so on a Pi3B you'd need to set both bits for USB boot with the additional wait time (the 3B+ has USB boot enabled by default).
