mnavon
Kodi and Home Assist simultanly
Wed Apr 25, 2018 9:58 am
Hi!
I have res-pi 2 B and I wonder if I can install Kodi so always be on, and in the background, the Home Assist will run.
Is it possible? if so how?
Rascas
Re: Kodi and Home Assist simultanly
Wed Apr 25, 2018 4:32 pm
Yes, Kodi and Home Assistant runs on Raspbian for example, I had both running some time ago with no problem.
To put it shortly, install Raspbian then install Kodi, you have a complete guide in this foruns on how to do it. Then follow the official instructions of Home Assistant to install it on Raspbian, it is really easy. The most difficult part is probably to configure your hardware/sensors/etc to your liking in HA.
Rascas
Wed Apr 25, 2018 4:38 pm
But I wouldn't recommend to use both on the same RPi. HA runs even on the Zero, and you get things separated.
Return to “Beginners”
