lwhistler
How can the raspberry be shutdown with a python script and no sudo?
Mon Apr 23, 2018 10:33 pm
klricks
Re: How can the raspberry be shutdown with a python script and no sudo?
Mon Apr 23, 2018 11:48 pm
If you are running as pi user then sudo is not required to shutdown or reboot. Works with or without sudo.
Use a subprocess to execute bash commands. Not the only way.....
Shutdown without sudo:
#!/usr/bin/python
import subprocess
subprocess.Popen(['shutdown','-h','now'])
This is reboot with sudo:
#!/usr/bin/python
import subprocess
subprocess.Popen(['sudo','shutdown','-r','now'])
pcmanbob
Tue Apr 24, 2018 10:07 am
#!/usr/bin/python
import subprocess
just tried this on stretch light using the pi user and it does not work
you get this error message
Failed to set wall message, ignoring: The name org.freedesktop.PolicyKit1 was not provided by any .service files
Failed to power off system via logind: The name org.freedesktop.PolicyKit1 was not provided by any .service files
Failed to open /dev/initctl: Permission denied
Failed to talk to init daemon.
just as I suspected you would because you always need sudo to run shutdown.
hippy
Tue Apr 24, 2018 11:43 am
Looking in the Python program which I run without sudo I have ...
while True:
  if GPIO.input(GPIO_BUTTON) == 0:
    result = os.popen("sudo shutdown -h now").read()
    return
  time.sleep(0.1)
Tue Apr 24, 2018 11:49 am
That program uses sudo.
It's very difficult to shutdown a Linux system without using sudo (or a setuid program owned by root) as the trigger for the systemd init program to run an orderly shutdown needs elevated privileges.
You can add a line to /etc/sudoers
pi raspberrypi =NOPASSWD: /usr/bin/systemctl poweroff,/usr/bin/systemctl halt,/usr/bin/systemctl reboot
That's assuming a userid=pi on a hostname=raspberrypi system (change as appropriate).
jbudd
Tue Apr 24, 2018 12:00 pm
You can do it with a root owned setuid executable.
But it has to be a compiled program - setuid is ignored by shell scripts (and Python, I guess)
/*sd.c  C Program to Shutdown or Turn Off the Computer in Linux.*/
#include <stdio.h>
#include <stdlib.h>
int main()
  system("shutdown -P now");
  return 0;
gcc -o sd sd.c
sudo chown root sd
sudo chgrp root sd
sudo chmod 6755 sd
#And to try it:
./sd
The C source is based on https://www.sanfoundry.com/c-program-shutdown-computer/ and since I don't know what the -P flag does, I'd advise you to research before trying it! (I tested it on my Pi though)
klricks
Tue Apr 24, 2018 12:16 pm
#!/usr/bin/python
import subprocess
The ability to shutdown without sudo was added to Raspbian DESKTOP quite some time ago. I don't know about the lite version?
The program I posted above works for me as well as running shutdown -h now from the command line.
bbqbailey
Mon Dec 17, 2018 4:19 pm
Douglas Lawson:
I tried your suggestion but it doesn't work for me:
Your suggested code:
Making the following changes (my systemctl is in /bin/systemctl), and my system name is RPI-Dev
pi RPI-Dev =NOPASSWD: /bin/systemctl poweroff,/bin/systemctl halt,/bin/systemctl reboot
Here is the error I get after rebooting the system via "sudo reboot" to make sure the changes to /etc/sudoer are picked up:
pi@RPI-Dev:~ $ reboot
Failed to set wall message, ignoring: Interactive authentication required.
Failed to reboot system via logind: Interactive authentication required.
My system info: cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
Do you have any other suggestions?
Thanks!
Mon Dec 17, 2018 4:44 pm
/sbin/reboot needs an entirely seperate line in your sudoers file.
bbqbailey
Mon Dec 17, 2018 4:53 pm
DougLawson: Thanks, but now I'm confused. Your code entry shows reboot on the same line; I just copied and pasted your code, while changing the location for the commands to /bin/ instead of /usr/bin/
So, are you saying your line, that contains "reboot" isn't correct?
Thanks, appreciate your help!
Mon Dec 17, 2018 4:58 pm
Reboot is a parameter for the systemctl program
pi raspberrypi =NOPASSWD: /sbin/reboot
should work, but I can't be bothered to test it.
bbqbailey
Mon Dec 17, 2018 5:38 pm
OK DougieLawson, found the problem; operator error.
Your code works.
What I didn't understand, was that I would still have to type sudo, as in "sudo reboot"; doing so causes the reboot without having to supply the password for the sudo command. I thought I would just have to type "reboot".
Thanks again
fbe
Mon Dec 17, 2018 6:48 pm
#include <stdio.h>
#include <stdlib.h>
int main()
  return 0;
mkdir -p ~/bin
cat > ~/bin/shutdown << _EOF_
#!/bin/sh
echo 'ALWAYS USE ABSOLUTE PATH IN system("...") FUNCTION IF YOUR PROGRAM IS EXPECTED TO RUN WITH ROOT PRIVILEGES'
_EOF_
chmod +x ~/bin/shutdown
Logout, login and run your sd program.
