79kiko
Network setting
Mon Apr 16, 2018 9:30 am
I Have installed OH2 on RPi3 with Openhabian. I have two local networks with two internet connections.
1.Network has IP 192.168.1.1
2.Network has IP 192.168.2.1
How can I set network in RPi? First will be connected using WIFI and second with cable connection. Second will be primary with connection to internet. It is possible?
RWild
Re: Network setting
Mon Apr 16, 2018 9:23 pm
This sequence of events is probably not quite correct but hopefully will be enough of a hint to help. I just did this a few days ago and have already forgotten the details. Believe I started by clicking a “up / down” arrows on the task bar and then used the drop down panels to assign a IPv4 address to the Ethernet adapter. My recollection is that the symbol on the task bar had changed to the typical wireless icon - sort of a broadcast disk. Just repeated the process of assigning a DHCP address manually for now.
I did the manual assigns as I am in the process of redoing all the address reservations and port forwards in both routers.
KLL
Re: Network setting
Tue Apr 17, 2018 1:33 am
i not try, but possibly this does what you want? ( incl. fix IP )
sudo nano /etc/dhcpcd.conf
and add at end:
interface eth0
static ip_address=192.168.1.100/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1 8.8.8.8 8.8.4.4
interface wlan0
static ip_address=192.168.2.200/24
static routers=192.168.2.1
static domain_name_servers=192.168.2.1 8.8.8.8 8.8.4.4
Who is online
Users browsing this forum: Baidu [Spider], gabegabe, mfa298, n67 and 51 guests
