AlkemaCJ
Newbie question - Raspbian Jessie
Mon Apr 16, 2018 7:55 am
Am keen to get going with a new project, and need some guidance please.
I downloaded the full "Noobs" zip under the download section, and have successfully installed, and connected to wife.
There is a project that I am keen to work on that requires Raspbian Jessie - does the download that I have, have Raspbian Jessie, or is that a completely different download ?
Appreciate your assistance
Re: Newbie question - Raspbian Jessie
Mon Apr 16, 2018 10:11 am
Since August 2017 Raspbian Stretch is the default and supported Operating System, look for a newer tutorial / blog ;)
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
Paeryn
Mon Apr 16, 2018 11:43 am
Should I ask how you connected your RPi to your wife or is that too personal? :lol:
alphanumeric
Mon Apr 16, 2018 11:45 am
You can get Jessie here, http://downloads.raspberrypi.org/raspbian/images/ if you really need it. ;)
pcmanbob
Mon Apr 16, 2018 12:22 pm
It might be a good idea to post a link to the project page you wish to follow, then someone might be able to tell you if it would also work if you used raspbian stretch instead of raspbian jessie.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
AlkemaCJ
Tue Apr 17, 2018 5:02 am
He he he... wife would not be impressed - that should read "wifi" 8-)
Link below for project I would like to try
https://circuitdigest.com/microcontroll ... nce-camera
Thanks!
KLL
Tue Apr 17, 2018 6:28 am
that is the installation for:
sudo apt install motion
and setup web server.
( for the use with USB camera!! )
so you just should try it + also on stretch +
__________________________________
you might consider not to start with motion,
like why not try a simple camera tool first.
lsusb you find it?
sudo apt install qv4l2 you see it?
pls copy all commands // best also all terminal content like from install ...//
so if you have problems // or just have to do it again later // you are prepared.
because if you come back here with
ITs NOT WORKING
without good documentation what you have done......
expect no good answer.
AlkemaCJ
Tue Apr 17, 2018 11:15 am
@KLL
Sage advice, will do so.
Thank you
AlkemaCJ
Fri Apr 20, 2018 4:48 pm
Worked like a charm
Ran into an issue the first time, but that was due to the time being incorrect, and as soon as I updated it, it worked..
