bentronix
Trying to figure out how to update HTML file
Mon Apr 16, 2018 2:33 am
I am new to Raspberry Pi. I am trying to find a way to save a certain part of a terminal output to a .html file to update a website.
Here's how the process would go.
User: Runs command
Pi: Outputs
"lorem ipsum dolor set amet 456
a1b2c3a1b2c3 temp=27.61"
Pi: Saves "27.61" to index.html
Is this possible, if so how?
If not, how can we make it possible? ;)
pcmanbob
Re: Trying to figure this out.
Mon Apr 16, 2018 10:30 am
Hi.
Yes its possible to write the temp to a file.
but without knowing a lot more about your existing program and what else you need in your html file I can only give you a general example.
import time
adc =  " The time is "
reporttime = (time.strftime("%H:%M:%S"))
result = open("/home/pi/index.html","w")
result.write(adc + reporttime + "\n")
csvresult.close
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
droleary
Contact: Website Skype
Re: Trying to figure out how to update HTML file
Mon Apr 16, 2018 1:33 pm
<command> | tail -n 1 | cut -d = -f 2 > index.html
If that's not enough, you need to be more detail in what you want than:
bentronix wrote:Pi: Saves "27.61" to index.html
