alexlf
Unable to locate package xrdp
Thu Apr 12, 2018 3:10 am
Hey guys!
I was trying to install xrdp but I get this error:
I'm not really familiar with linux, so please help me out here. I want to RDP to my rasp pi from windows 10 machine.
Thank you!
Re: Unable to locate package xrdp
Thu Apr 12, 2018 9:42 am
Hey guys!
Thank you!
Raspbian has xrdp in repository:
sudo apt-get update
sudo apt-get install xrdp
Though xrdp conflicts with Raspbians included RealVNC, so you will need to completely remove.....
adieu
My other Computer is an Asus CS10 ChromeBit
klricks
Thu Apr 12, 2018 12:17 pm
Hey guys!
Thank you!
RealVNC is already installed in Raspbian and is much better than RDP.
Enable VNC by interfaces menu in sudo raspi-config or GUI config tool then reboot.
Install viewer app for Windows from here: https://www.realvnc.com/en/connect/download/viewer/
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
JohnBeardmore
Sun Apr 15, 2018 11:32 pm
Given the resolution issues with VNC, did anybody find out why xrdp can't be located ?
Cheers J/.
Author of oBeMS open source Building energy Management System.
Automatic Meter Reading (AMR), Building Management System (BMS),
Building Energy Management System (BEMS), Infrastructure Control System (ICS).
See: http://t4sustainability.co.uk/oBeMS/
JohnBeardmore
Sun Apr 15, 2018 11:40 pm
OK, I'm going to answer my own question.
Despite having run it no more than 20 minutes ago, I had to run 'apt-get update' again before apt would find and install it.
Having installed it, the resolution is good as ever which blows away VNC, and I confirm that I didn't have to uninstall anything on Stretch.
Cheers, J/.
KLL
Sun Apr 15, 2018 11:45 pm
JohnBeardmore wrote: did anybody find out why xrdp can't be located ?
Cheers J/.
try
apt-cache show xrdp
Package: xrdp
Version: 0.9.1-9+deb9u2
______________________________
JohnBeardmore wrote: Given the resolution issues with VNC,
yes i have some too: working headless, and
with RASPBIAN Desktop / boot to CLI
and no HDMI connected
it is required to run sudo raspi-config and adjust the resolution [7 advanced options ][A5 resolution][?DMT mode 35]
JohnBeardmore wrote:I confirm that I didn't have to uninstall anything on Stretch.
who say you need to uninstall anything? last time i tried the install of xrdp just breaks VNC
but all what counts is: that you are happy now.
klricks
Mon Apr 16, 2018 5:19 pm
Cheers, J/.
An additional sudo apt update is required after.... even immediately after..... the latest upgrade. After doing that once then it should work as before.
There is no resolution problem with RealVNC. However if there is no HDMI monitor attached then the settings revert to composite resolution. To fix that the force hotplug and resolution group and mode must be set in config.txt. You can use sudo rasp-config or the GUI config tool to do that.
IMO RealVNC is far better than xrdp.
Mon Apr 16, 2018 11:05 pm
Cheers J/.
What resolution issues?
Try adding
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=82
to /boot/config.txt to get 1920x1080 for RealVNC.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
JohnBeardmore
Tue Apr 17, 2018 12:21 am
Good to know there is a way to change the resolution in VNC. A shame it's not a little more obvious. Maybe it is if you know enough.
But I thihnk I'll stick with xrdp, not least because its said to work better over low bandwidth links, and some of our clients have very low bandwidth.
Cheers, J/.
Mancolt
Wed Jun 06, 2018 12:59 am
I was able to get RealVNC working thanks to all of the information in this thread. I just initially configured my RealVNC on the Pi with a monitor hooked up via HDMI, and connected via RealVNC on a laptop, then shutdown the Pi. Next I unplugged the monitor and turned the Pi back on. After connecting to the Pi via RealVNC on the laptop, I noticed the resolution issues. I went into the Pi's GUI (Preferences --> Raspberry Pi Config --> System --> Set Resolution and then selected DMT Mode 82. Now it looks great on the laptop screen.
