beira
Start PiCamera at startup
Mon Apr 09, 2018 9:44 am
I'm new at raspberry. So i need to start the picamera ate the start of the raspeberry. I only need to do live at a monitor.
were can i place the raspivid -t 0 command to start automatically?
i have this sripy at startup but it wont start
from picamera import PiCamera
from time import sleep
camera = PiCamera()
camera.framerate = 15
camera.start_preview()
KLL
Re: Start PiCamera at startup
Mon Apr 09, 2018 4:49 pm
hi, try to follow, i hope you can copy paste commandlines and file content into your terminal:
( rev. 2018-04-12 )
cd
mkdir projects
cd projects
mkdir RPI_CAM
cd RPI_CAM
nano RPI_CAM.py
#!/usr/bin/python3
camera = PiCamera()
camera.led = False
camera.resolution = (640,480)
camera.framerate = 5
camera.sharpness = 0
camera.contrast = 0
camera.brightness = 50
camera.saturation = 0
camera.ISO = 0
camera.video_stabilization = False
camera.exposure_compensation = 0
camera.exposure_mode = 'auto'
camera.meter_mode = 'average'
camera.awb_mode = 'auto'
camera.image_effect = 'none'
camera.color_effects = None
camera.rotation = 0
camera.hflip = False
camera.vflip = False
camera.crop = (0.0, 0.0, 1.0, 1.0)
print("show web cam")
#camera.start_preview()  # if need fullscreen use later
camera.start_preview(fullscreen=False, window = (100, 100, 640, 480))
sleep(10)
MYINPUT = input("stop and take picture")  # will wait for answer and show CAM forever
camera.capture('/home/pi/Pictures/RPI_CAM_py_image.jpg')
camera.stop_preview()
print("use gpicview to see Pictures/RPI_CAM_py_image.jpg")
nano RPIcamshow.sh
#!/bin/bash
for N in {30..5..-5}
do
   echo $N'sec'
   env sleep 5
done
TODAY=$(date +'%Y-%m-%d_%H:%M:%S')
echo $TODAY
/usr/bin/python3 /home/pi/projects/RPI_CAM/RPI_CAM.py
echo 'show picture'
gpicview /home/pi/Pictures/RPI_CAM_py_image.jpg
echo 'press ENTER'
read
chmod +x RPIcamshow.sh
test with
./ RPIcamshow.sh
nano RPIcamshow.desktop
[Desktop Entry]
Type=Application
Comment=RPI cam show
Name=RPI cam
Icon=/usr/share/pixmaps/guvcview/guvcview.png
Exec=lxterminal -e /home/pi/projects/RPI_CAM/RPIcamshow.sh
Terminal=false
cp /home/pi/projects/RPI_CAM/RPIcamshow.desktop /home/pi/Desktop/RPIcamshow.desktop
( you might see not showing that same icon )
test with double click on it
for auto start try
cd
cd .config
ls
mkdir autostart
# if not exist
cp /home/pi/projects/RPI_CAM/RPIcamshow.desktop /home/pi/.config/autostart/RPIcamshow.desktop
sudo reboot
after test you can make the preview big again, use the while true: and shorten the timer...
beira
Wed Apr 11, 2018 1:51 pm
Thanks,
It works!!!:)
Now for fullscreen ate startup and to be always on until reboot i have to supress this lines?
print("show web cam 10 sec and make snap")
if True:
#while True: # this use later if all works out, but how to stop it? do not enable while AND autostart together
sleep(10)
#print("use gpicview to see Pictures/RPI_CAM_py_image.jpg")
KLL
Wed Apr 11, 2018 2:01 pm
Thanks,
It works!!!:)
if True:
ok, ( i prepared for that ) just change to
#if True:
while True:
	sleep(10)
but i warned you, you need to know how to stop it!
beira
Wed Apr 11, 2018 2:05 pm
Thanks once again,
When i do that it goes to the picture dont go live
KLL
Wed Apr 11, 2018 2:11 pm
beira wrote: When i do that it goes to the picture dont go live
?? when
while True:
is enabled, it will sleep 10 sec again and again, and never come to the "make a picture part???
also python and bash script never stop!
https://www.dotnetperls.com/while-python
beira
Wed Apr 11, 2018 2:17 pm
I did this
#!/usr/bin/python3
camera = PiCamera()
camera.contrast = 0
camera.ISO = 0
camera.rotation = 0
#if True:
sleep(10)
KLL
Wed Apr 11, 2018 2:30 pm
if you not use ["code"] tags, we not see if the sleep(10) has a [tab] in front ( so is looped by while )
again:
print("show web cam ")      #10 sec and make snap")
#if True:
	sleep(10)
shows:
30sec
25sec
20sec
15sec
10sec
5sec
2018-04-11_21:26:10
show web cam
and never stops,
live cam window and that bash terminal window open.
______________________________________________________
if i select the bash window and [ctrl][c]
cam stops and i see this
30sec
25sec
20sec
15sec
10sec
5sec
2018-04-11_21:26:10
show web cam
^CTraceback (most recent call last):
  File "/home/pi/projects/RPI_CAM/RPI_CAM.py", line 29, in <module>
    sleep(10)
KeyboardInterrupt
show picture
beira
Wed Apr 11, 2018 3:02 pm
Thanks for all. :D :D :D :D
Return to “Beginners”
