Libreoffice 6 in raspbian
Posted: Sun Mar 25, 2018 6:51 am
by awachens
Hi guys how can i install Libreoffice 6 in raspbian ?
When i do dpkg -i *.deb
Make some errors like arch is not same... How can i fix this ? I have armv7 (so this is 32?)
i386 isn't installable in Raspbian ?
Regards !
Re: Libreoffice 6 in raspbian
Posted: Sun Mar 25, 2018 7:06 am
by rpdom
Raspbian on the Pi is armhf arch which is nothing like i386.
There doesn't appear to be an armhf version of LibreOffice 6 available for download. You could build it from source, but that would take a while on a Pi.
Posted: Sun Mar 25, 2018 7:43 am
by fruitoftheloom
Regards !
Raspbian is a re-spin of Debian ARMHF.
LibreOffice 6.xx in Debian Testing:
https://packages.debian.org/buster/libreoffice
Posted: Sun Mar 25, 2018 8:04 am
by awachens
Good morning, i dont understand... Why the guides use .deb to install packages in raspbian then ?
Posted: Sun Mar 25, 2018 8:11 am
by fruitoftheloom
What guide are you following ? is it specifically for Raspbian Stretch Operating System ??
Posted: Sun Mar 25, 2018 8:25 am
by B.Goode
Because Raspbian is an RPi (armhf) variant of Debian, and .deb files are the packaging system used by Debian and thus by Raspbian also.
But .deb package files are not technology-independent and thus are not portable across different machine architectures.
Posted: Sun Mar 25, 2018 8:27 am
by awachens
Then how can i know what packages .deb is for raspbian and what for debian only ?
Thx !
Posted: Sun Mar 25, 2018 8:34 am
by B.Goode
Thx !
Looking, for example, at the link already provided, you scroll down to Download and look in the Architecture column for armhf.
Some packagers and developers confuse the issue and fail to acknowledge that Linux can run on any architecture other than 'wintel/x86' hardware. If you see a package advertised as being for Linux but offering only 32/64 bit options it has almost certainly not been built with the RPi in mind.
Posted: Sun Mar 25, 2018 8:41 am
by rpdom
The clue is in the name of the file. It always includes an arch string.
The basic naming convention goes like this:
packagename_versionnumber_amd64.deb is for x86 64 bit architecture (it's called amd64 because AMD released the first decent chips in this arch)
packagename_versionnumber_i386.deb is for x86 32 bit architecture
packagename_versionnumber_armhf.deb is for arm 32 bit architecture with hardware floating point support (Raspbian*)
packagename_versionnumber_all.deb will run on any architecture. This is often things like pure data, shell scripts, python programs etc.
*Non-Raspbian armhf packages can be used on Pi2 and Pi3, but not Pi1 and Pi0 - unless they say they are suitable for those models.
Posted: Sat Nov 24, 2018 4:31 pm
by code_exec
You can now run LibreOffice 6.1 on the Raspberry Pi 2 and 3 as if it were running natively thanks to Pi386 emulation layer, an emulation layer that allows you to install 32-bit x86 software inside of an i386 environment and then run this software on the Pi transparently.
viewtopic.php?f=63&t=226604
I forgive jamesh and others who said that downloading random files from websites such as MediaFire is risky, it is indeed important to be careful about what you download, but Pi386 is safe software and does not give you any viruses. If you think MediaFire is an unsafe cloud hosting platform, please do suggest an alternative cloud hosting service that could be considered more safe than MediaFire.
by code_exec
Whoops, didn't notice that this thread has had no activity since March. Sorry about that.
Posted: Tue May 28, 2019 9:30 am
by jihun kim
I was build libreoffice.
https://github.com/istandthon7/core/rel ... ce-6.2.3.2
And You can change language.
if font is unreadable, compare with default libreoffice 5.
Posted: Tue May 28, 2019 10:11 am
by fruitoftheloom
Just wait until Raspbian Buster is released ?
