TimB101 wrote: ↑Sat Dec 15, 2018 8:18 pm
I'm injecting power via the GPIO pins which bypasses the polyfuse, it's impossible to get my overclock with power in via the (bloody awful) USB B micro socket.
That is a bad idea. Most times the microUSB socket is not a problem, are you sure your cable to microUSB is adequate (18AWG wires for preference)?
With the polyfuse bypassed and excess voltage applied you are well into Pi Abuse territory.
Also, increasing the supply voltage will not improve the Pi's performance, since the SOC has on-board regulators to lower voltages for almost everything.
2.7A is well above what the Pi should draw -- do you have any peripherals drawing 5V through the Pi? If the Pi itself is using almost 14.5W, the temperatures are absolutely amazing.
Don't worry about my Pi
Based on what you have said, worry about your Pi's health is fully justified.
