Fan174
Flask server is not working
Tue Mar 20, 2018 6:21 am
Hello friends
I am trying to run flask server on PI3 rasbain but no luck it say site can not be reached
  from flask import Flask
  app = Flask(__name__)
  @app.route('/')
  def index():
      return 'Hello world'
  if __name__ == '__main__':
      app.run(host='0.0.0.0', debug=True, port=8080)
[email protected]:~ $ cd webapp
[email protected]:~/webapp $ python3 app.py
I am trying with different port number 5000 and 4996 but no luck
[email protected]:~ $ sudo apt-get update
Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists... Done
[email protected]:~ $ sudo apt-get -y upgrade
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[email protected]:~ $ sudo apt-get -y install python3-pip
python3-pip is already the newest version (9.0.1-2+rpt2).
[email protected]:~ $ sudo pip3 install flask
texy
Re: Flask server is not working
Tue Mar 20, 2018 7:59 am
Same as this person, but a different issue !!
viewtopic.php?f=91&t=208492
Texy
Fan174
Tue Mar 20, 2018 9:42 am
Texy
how to troubleshoot the problem, I don find any error
charlietango_22
Tue Mar 20, 2018 11:15 am
Texy
are you trying to connect locally (from the same PI) or remotely from another machine?
I'm asking because your code runs on my PI (PI 3 B, Stretch) without any issue. This is my output when launching the py file:
[email protected]:~ $ python flasktest.py
 * Running on http://0.0.0.0:8080/ (Press CTRL+C to quit)
 * Restarting with stat
 * Debugger is active!
 * Debugger PIN: 263-868-971
Fan174
Tue Mar 20, 2018 12:09 pm
Texy
there was some space problem but now server is running on Pi. I was trying to control led but it say url not found
from flask import Flask, render_template
from flask_responses import  json_response, xml_response, auto_response
import RPi.GPIO as GPIO
import datetime
@app.route("/toggle", methods=['post'])
def toggle():
 GPIO.setmode(GPIO.BOARD)
 GPIO.setup(7, GPIO.OUT)
 state = not GPIO.input(7)
 GPIO.output(7,state)
 return json_response({"status": state}, status_code=201)
if __name__ =="__main__":
 app.run(host='0.0.0.0', debug=True, port=4000)
* Running on http://0.0.0.0:4000/ (Press CTRL+C to quit)
* Debugger PIN: 283-476-405
192.168.0.40 - - [20/Mar/2018 11:55:49] "GET / HTTP/1.1" 404 -
192.168.0.40 - - [20/Mar/2018 11:55:49] "GET /favicon.ico HTTP/1.1" 404 -
192.168.0.40 - - [20/Mar/2018 11:55:59] "GET / HTTP/1.1" 404 -
charlietango_22
Tue Mar 20, 2018 12:34 pm
You configured your server to handle http request aimed at [host]:[port]/toggle, if you send an http request to get / , it won't work.
Examples:
192.168.0.40:4000 -> 404 not found
192.168.0.40:4000/toggle -> should work.
Fan174
Tue Mar 20, 2018 12:50 pm
Examples:
I tried that's not working
charlietango_22
Tue Mar 20, 2018 3:47 pm
what exactly is 'not working'?
SeanElder
Tue Mar 20, 2018 5:50 pm
HAHAHA hello My friend. I am starting on the raspberry pi curriculum now. you can find it here https://curriculum.raspberrypi.org/ .
Have a look at each creator page and see if its more your level. It is mine.
:mrgreen:
Fan174
Wed Mar 21, 2018 7:58 am
When I type ip address on browser it say url not found
requested url was not found on the server
I think my code is wrong. I don't know exactly what's the problem
KLL
Wed Mar 21, 2018 8:17 am
you must show us
-a- the actual python code
-b- the start line in terminal and the msg on it
-c- the full URL you type in browser
-d- of same RPI or a other computer in your network
_______________________________________________________________
when you start your ( python flask ) server you see like
[email protected]:~/projects/py3_flaskserver $ ./start
* Debugger pin code: 243-692-839
for STOP must press [ctrtl][c] in that terminal window
if you see a different msg at start please tell us.
________________________________________________________________
if you start the browser on this RPI use
or
http://localhost:4000/
or
http://127.0.0.1:4000/
( all 3 should work )
on a browser of a computer on your LAN need the IP of this RPI like with
ifconfig
or point with mouse over your WLAN ICON in the HEADER line
tooltip will tell you the IP of this RPI.
like
192.168.1.203/24
so must use in PC browser:
http://192.168.1.203:4000/
_________________________________________________________________
working tip:
in the following i show commands (bold) needed to type into terminal window ( in desktop OR VNC desktop OR PUTTY / SSH)
and also code / content for files...
i expect that you can copy paste from this browser / forum post
first the command lines and execute with [ENTER]
and then the content into the editor window.
you have a working directory like
/home/pi/projects/py3_flaskserver/
( if not make it and go there )
and inthere a python code: ( edit with)
nano app.py
#!/usr/bin/python3
@app.route('/')
def index():
        app.run(debug=True, host='0.0.0.0', port=4000)
you should make a bash script to start the thing:
nano start
#!/bin/bash
python3 /home/pi/projects/py3_flaskserver/app.py
and make it executable
chmod +x start
now you could use
./start
but better
optional / just to make it more easy
nano start_my_server.desktop
[Desktop Entry]
Type=Application
Name=start my_server
Exec=/home/pi/projects/py3_flaskserver/start
Icon=network
Comment=start python3 flask webserver
Terminal=true
X-KeepTerminal=false
Categories=Network;
and
nano browse_my_server.desktop
[Desktop Entry]
Type=Link
URL=http://localhost:4000
Name=browse my_server
Comment=start browser python3 flask webserver
this 2 .desktop files pls copy to the desktop at /home/pi/Desktop/
cp start_my_server.desktop /home/pi/Desktop/start_my_server.desktop
cp browse_my_server.desktop /home/pi/Desktop/browse_my_server.desktop
even i used the "nano" editor here better practice for the python code is
geany app.py
as that can show the blank and TAB indentation what is so essential for python
you see the 2 desktop icons for start server and start browser, also the open GEANY editor window and the optional direct START from there,
as it is not ONLY a editor.
cfo64nc
Tue Nov 27, 2018 7:37 pm
I had the same problem. I was trying to run the flask app using:
$ export FLASK_APP=app.py flask run
when I checked from another terminal session with 'ss -l' I got:
$ ss -l | grep 5000
tcp LISTEN 0 128 127.0.0.1:5000 *:*
Note that the app is only listening on the address 127.0.0.1 (i.e., localhost, local connections only).
I solved it by running the Flask app using python. e.g.
$ python app.py
which resulted in 'ss -l' showing the port being available from all addresses:
$ ss -l | grep 5000
tcp LISTEN 0 128 *:5000 *:*
Note that the app is now listening on all addresses (*.5000).
Hope that helps.
