RPi with Edimax EW-7811Un problem
Posted: Tue Oct 23, 2012 3:12 pm
hi guys
have a problem you experts can help me with. My RPi has an Edimax EW-7811Un wifi module. I'm running a clean 2012-09-18-wheezy-raspbian build on it and use the WPA_GUI to gain access to the internet.
Now the problem is very simple to formulate. I don't see my router... I can see the routers of all my neighbours, but my router is not showing. To make things even worse, i can internet on the RPi through tethering with my samsung galaxy S2 without a problem, so the module works.
All my other wifi devices are working fine and all are recognizing my linksys router and SSID broadcast. When i connect the enermax module with my main windows 7 pc, i can see my router just fine with a 100% signal ( the pc is in the same room as the RPi).
Does anyone have any idea on how to fix this, it would be very much appreciated
cheers!
cheers!
