Error of using cocos2d python 3.5
Posted: Thu Mar 15, 2018 4:18 pm
by Ivan219
Hello, I have problem with use of the cocos2d on python 3.5
I install cocos2d with pip3. Cocos2d successfully installed.
I tried to start program:
https://github.com/CoderDojoLu/cocos2d- ... loWorld.py
But I got:
Cannot import cocos. Did you run 'pip install cocos2d' ?
  File "/home/pi/Desktop/test.py", line 7, in <module>
    class HelloWorld(cocos.layer.Layer):
NameError: name 'cocos' is not defined
How I can resolve problem?
Re: Error of using cocos2d python 3.5
Posted: Fri Mar 16, 2018 3:00 am
by KLL
hi Ivan,
bad style, just missing the main required info,
but i was able to get the same error:
pi@RPI3:~/projects/cocos $ python helloWorld.py
  File "helloWorld.py", line 10, in <module>
when i started with python .. === python2x
but not installed with pip
( like you i used pip3 so must start with python3 )
pi@RPI3:~/projects/cocos $ pip3 install cocos2d
Collecting cocos2d
  Downloading https://www.piwheels.org/simple/cocos2d/cocos2d-0.6.5-py3-none-any.whl (288kB)
    100% |████████████████████████████████| 296kB 651kB/s
Collecting six>=1.4 (from cocos2d)
  Downloading six-1.11.0-py2.py3-none-any.whl
Collecting pyglet>=1.2 (from cocos2d)
  Downloading pyglet-1.3.1-py2.py3-none-any.whl (1.0MB)
    100% |████████████████████████████████| 1.0MB 274kB/s
Collecting future (from pyglet>=1.2->cocos2d)
  Downloading https://www.piwheels.org/simple/future/future-0.16.0-py3-none-any.whl (489kB)
    100% |████████████████████████████████| 491kB 309kB/s
Installing collected packages: six, future, pyglet, cocos2d
Successfully installed cocos2d-0.6.5 future-0.16.0 pyglet-1.3.1 six-1.11.0
so you miss to show the
- - install line
- - start line
beginning with IDLE3 can help
anyhow possibly better to do the full install like here
start with download zip file ...
what includes docs and samples.
Posted: Fri Mar 16, 2018 12:22 pm
by Ivan219
Thank for your answer. I tried to do this steps again:
pi@raspberrypi:~ $ cd Desktop
pi@raspberrypi:~/Desktop $ pip3 install cocos2d
Collecting cocos2d
  Using cached six-1.11.0-py2.py3-none-any.whl
  Using cached pyglet-1.3.1-py2.py3-none-any.whl
pi@raspberrypi:~/Desktop $ python3 test.py
  File "test.py", line 7, in <module>
But the error still remains.
Posted: Fri Mar 16, 2018 12:38 pm
by KLL
not look good,
sorry when i created that error by using "python" instead "python3" the error talk about
LINE 10
but you report:
hm, pls. post your file test.py
just make sure, is your system updated?
Posted: Fri Mar 16, 2018 12:44 pm
by Ivan219
try:
	import cocos
except:
	print('Cannot import cocos. Did you run \'pip install cocos2d\' ?')
# define a simple HelloWorld() class that inherits from cocos.layer.Layer (making it a sub-class of it)
	# __init__ is run every time you instantiate the class
	def __init__(self):
		# Always call super in the constructor
		super(HelloWorld, self).__init__()
		# label will become an object with all the necessary to display a text, with font TimesNewRoman and it will be center-anchored
		# Note: .Label is a subclass of CocosNode
		label = cocos.text.Label('Hello, world', font_name='Times New Roman', font_size=32, anchor_x='center', anchor_y='center')
		# set the position of our text to x:320 y:240
		label.position = (320, 240)
		# add our label as a child. It is a CocosNode object, which know how to render themselves.
		self.add(label)
# our main function
def main():
	# We initialize the director, that takes care of our main window
	cocos.director.director.init()
	# We instantiate hello_layer with our HelloWorld() class
	hello_layer = HelloWorld()
	# Now we create a .Scene and pass our HelloWorld() object stored in hello_layer, as a child
	main_scene = cocos.scene.Scene(hello_layer)
	# All setup now. Let's run our main_scene
	cocos.director.director.run(main_scene)
	# The above could have been compacted to:
	# cocos.director.director.run(cocos.scene.Scene(HelloWorld()))
if __name__ == '__main__': main()
Posted: Fri Mar 16, 2018 12:55 pm
by KLL
your code works here!
( you deleted only the headerline, no problem as long you not want to start it by "./test.py" )
actually i have no idea whats wrong with your system...
