Convert acceleration to calories (energy)
Posted: Mon Mar 12, 2018 2:32 pm
by Sherry123
How to convert acceleration to calories (energy) from human movement
Using sensor accelerometer
Re: Convert acceleration to calories (energy)
Posted: Mon Mar 12, 2018 2:38 pm
by jamesh
F=ma
So you need to know the mass, combine that with acceleration to find out the force. Work is force times distance, so you need to know distance, then you can use that to give you Joules used, then simple convert to calories.
Distance could be calculated using s = ut+1/2at^2, or some variation thereof, basic movement equations.
Might be an easier way.
Posted: Mon Mar 12, 2018 2:39 pm
by DougieLawson
It's not easy, you need a base line calories per hour, weight, height, age and gender to make any energy measurement turn into a fake kilo calorie (kCal) measurement.
The classic example of how NOT to do it, is the Concept2 rowing ergometer (they assume everyone is a 25% efficient energy burner, burns 300kCal/hr doing no active work and weighs in at 80Kg - you'll see a immediate flaw there).
http://eodg.atm.ox.ac.uk/user/dudhia/ro ... #section11
It's in no way as simple as F=ma.
Posted: Mon Mar 12, 2018 3:02 pm
by PiGraham
Sherry123 wrote: ↑Mon Mar 12, 2018 2:32 pm
You want to make a Fitbit?
http://www.dailymail.co.uk/sciencetech/ ... meter.html
Steps to calories
https://www.livestrong.com/article/2380 ... -calories/
Accelerometer to step count
http://www.analog.com/en/analog-dialogu ... celer.html
