Total_Insomnia
Remotely updating code on multiple devices easily
Sat Mar 03, 2018 10:11 pm
I would like to start using some Raspberry Pis for some remote sensor monitoring stuff I am doing at work. The problem is I would want to be able to remotely update code on multiple devices at once.
It's not inconceivable for me to have 30+ Pi's deployed at a given time and if every time I needed to update code (which is unfortunately pretty regularly) I would have to do it individually for each Pi it would quickly grow to be a pain.
Any ideas on how I could do this automatically?
I'm thinking worst case scenario I could put the code in a cloud file storage place (preferably with an API) then have the Pi periodically check for updated code but that seems kinda sloppy.
Any ideas are much appreciated.
KLL
Re: Remotely updating code on multiple devices easily
Sun Mar 04, 2018 12:58 am
you want to do it
remotely?
means operate each RPI ( like via SSH putty?)
or
automatically?
anyhow you have the problem that there is a OLD CODE RUNNING!
requires to stop that process / overwrite code / restart ( with new ) program.
you could change the autostart of the program at boot
to first check/get new version from cloud ( like dropbox...)
but that still would require that you need to spawn remotely a reboot
_____________________________________________________
short dropbox info:
-a- setup account and get token
-b- install uploader
git clone https://github.com/andreafabrizi/Dropbox-Uploader.git
-c- use a alias / like in
nano .bash_aliases
alias drop='/home/pi/Dropbox-Uploader/dropbox_uploader.sh'
-d- at first call of
drop must give that long token: aodsifgjn;qoivaweFV[...
then can use ( from the RPI where you developed the new code )
drop upload MYPROG.py .
and on each RPI what needs the copy
drop download MYPROG.py .
test if the file overwrite is working, even while the old version still is running?in use by python?
droleary
Contact: Website Skype
Sun Mar 04, 2018 4:14 pm
What you want is known as configuration management. There are many solutions available, which generally break down into the choice of pushing or pulling. I usually want as little extra software running on the RPi as possible (especially if I deploy the less powerful 0W), so I tend to go with Ansible and push out changes.
PingoBags
Mon Mar 05, 2018 6:03 pm
You could always create an app to automatically handle it via ssh.
Store all the pi user/pass and ip's in a text file.
Loop through them all to upload and run the new scripts if needed.
I do something similar from my win pc.
dr_genestealer
Thu Apr 12, 2018 10:18 pm
Seems that Ansible may be the way to go
viewtopic.php?t=208519
rockrilvas
Fri Jun 26, 2020 12:40 pm
Hi All,
I do need to keep all my RPIs update over WIFI connection only, is that a proper and safe way to do?
jahboater
Fri Jun 26, 2020 2:19 pm
I just use a trivial script:
Multiple entries like this to distrubute the latest source, one line per remote Pi:
/usr/bin/scp project1.c project2.c makefile pi@host:project
Multiple entries like this to build it on each Pi and install it:
ssh -t pi@host '(cd project; make; sudo make install)'
Be sure to use passwordless authentication (use ssh-copy-id) so the scripts work unattended.
You will of course need to fill in your own names and use WinSCP etc for windows, but its simple enough.
Pi4 8GB and Pi4 4GB running Raspberry Pi OS 64-bit
Return to “Beginners”
