bensimmo
Re: if x < y then x = y
Mon Feb 26, 2018 2:07 pm
Lots of methods, I would pass the variables current_windchill and new_windchill in to a function and retrun it, removing globals.
But then it depends on other code around it and if anything else is in the function
wind_chill_max = 0  #setup at start of python for variables, unless you get positive/negative windchill/feels like ?
def check_windchill_max(wind_max, wind_new):
   return max(wind_max, wind_new)
wind_chill = from_ardunio_data
wind_chill_max = check_windchill_max( wind_chill_max, wind_chill )
print("Max ",wind_chill_max)
bensimmo
Mon Feb 26, 2018 2:17 pm
Dangermoth wrote:
Mon Feb 26, 2018 2:04 pm
Sorry I got called away,
It's still not working, I'm kind of thinking I should do the calculation and comparison on the Arduino as I do with the max / min temperature, this looks to be a lot more in depth using Python than I thought.
Post your code up.
Dangermoth
Mon Feb 26, 2018 4:37 pm
Thanks for your help guys, I was kind of hoping this would only take a couple of minutes as per my little 'C' example above but Python can be a very tricky and frustrating beast when your not used to it.
I don't have a internet connected to the Pi at the moment so can't post the code.
