como usar webcam integrada en el monitor - how to use webcam integrated in the monitor
Posted: Wed Feb 21, 2018 9:23 pm
by cainfoxy
Hola!
Estoy empezando con mi raspberry pi 3 y utilizo un monitor Asus VK246H que incorpora una webcam en el marco. Conectado vía HDMI con otros sistemas operativos he podido utilizar la webcam, lo estoy intentando con Raspbian y no lo consigo.
¿Alguien sabe que debo hacer?
Lo único que he hecho ha sido activarla en el apartado del archivo raspi-config en la opción 5.
No sé como averiguar si Raspbian la ha detectado e instalado.
Muchas gracias
Hello!
I'm starting with my raspberry pi 3 and I use an Asus VK246H monitor that incorporates a webcam in the frame. Connected via HDMI with other operating systems I could use the webcam, I'm trying with Raspbian and I can not.
Does anyone know what I should do?
The only thing I have done was to activate it in the section of the raspi-config file in option 5.
I do not know how to find out if Raspbian has detected and installed it.
Thank you very much
Re: como usar webcam integrada en el monitor - how to use webcam integrated in the monitor
Posted: Thu Feb 22, 2018 3:44 am
by KLL
https://www.asus.com/Monitors/VK248H/ say
Real-time Video Communication ....
Plug-and-play for easy connection and easy use through the USB interface without installing extra drivers.
so, did you connect the USB cable to RPI USB port?
did you install
sudo apt-get install qv4l2
for testing usb cam?
