nick8967
working with microphone on raspberry pi2
Fri Feb 16, 2018 11:17 pm
Hello, has anyone worked with this: https://www.element14.com/community/com ... udio-space ?
Is it compatible with raspberry pi 2?
Because I am beginner on raspberry I want to ask, if I can use raspberry as Arduino, meaning to upload code to it and do something... Or should I install an operating system first? I want to record sound basically..
Re: working with microphone on raspberry pi2
Sat Feb 17, 2018 1:12 pm
Raspberry Pi is a SBC without an Operating System it will not achieve anything.
Cheapest option is a USB Microphone or if you have a 3.5mm Mic already a £1 USB Sound Card...
Adieu
nick8967
Sat Feb 17, 2018 2:12 pm
Thank you for the info. Because I want to process the sound I will record, is it possible to use software/code in python, that does this, if I use USB microphone? Or it is better to use A/D converter?
ghans
Sun Feb 18, 2018 8:07 am
Use a cheap USB soundcard. The drivers are included in Raspbian and will get loaded
automatically, this doesn't apply to bare ADC chips.
ghans
nick8967
Sun Feb 18, 2018 1:37 pm
Thank you. Can I transfer the recorded file in a matrix in python code? In other words can I "see" the recorded file as bytes somehow?
ghans
Sun Feb 18, 2018 3:03 pm
Use numpy and PyAudio together :
https://stackoverflow.com/questions/249 ... umpy-array
ghans
Return to “Beginners”
Who is online
Users browsing this forum: No registered users and 21 guests
