ankur_r
Re: 16 gb raspberry card prepration
Wed Feb 07, 2018 2:50 pm
Hi All,
If its a fake or damaged card then why is it proper;y working on ubuntu laptop and able to partition/read/write files etc ?? I feel in the beckground some matching code or something is lying due to which its only not able to boot..what u say ?? Without testing something reaching a conclusion could be correct but its not with full base...to prove the same we need to test this card ?
Is anyone can let me know some card testing software or techniques ??
Regards.
Ankur
Wed Feb 07, 2018 3:04 pm
Hi All,
Regards.
Ankur
I am completely baffled, having used in the past W32DiskImager and DD and now Etcher, it just works.
Though have had a few used SD Cards which had to format in a Digital Camera to make them usable.
H2testw can test for fake SD Card...
RPi 4B 4GB (SSD Boot)..
drgeoff
Wed Feb 07, 2018 3:19 pm
Hi All,
Regards.
Ankur
Putting one or a few small files on a card does not test it sufficiently.
You said you are running Ubuntu. That is why I gave you links to testing a card with a Linux computer. If you have, or have access to, a Windows computer then use H2testw.
drgeoff
Wed Feb 07, 2018 3:21 pm
Hi All,
Regards.
Ankur
Putting one or a few small files on a card does not test it sufficiently. The partition table and those few files will be placed at the beginning of the card. That leaves a lot of the card untested.
ankur_r
Thu Feb 08, 2018 2:05 pm
Hi All,
Thanks for all support of all learned members. I have checked card via H2testw. In writing and verification one error shown with one raspbian formatted card.
After which to check complete card, I reformat as second partition was in ext filesystem which is not readable in windows, in fat32 and then verification process doesn't produce any error .
Finally i am able conclude card is fine. Using same hardware like reader and card.
Now what further diagnosis can be done to rectify the issue.
I don't think for this task such big discussion are required. Some very fundamental error is happening , unfortunately we are not able to catch .
Can someone suggest what best remedy can be applied in this situation as I am also feeling exhausted now.
Regards .
Ankur
