Yes, I have tried that. Several times in fact. I've attached the screen output from the last effort.
pi@PCBMill:~ $ npm install -g cncjs
npm WARN peerDependencies The peer dependency react@^16.0.0 included from react-grid-system will no
npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency
npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
> serialport@6.0.4 install /home/pi/.nvm/versions/node/v4.8.7/lib/node_modules/cncjs/node_modules/serialport
> prebuild-install || node-gyp rebuild
prebuild-install info begin Prebuild-install version 2.5.0
prebuild-install info looking for local prebuild @ prebuilds/serialport-v6.0.4-node-v46-linux-arm.tar.gz
prebuild-install info looking for cached prebuild @ /home/pi/.npm/_prebuilds/https-github.com-
EmergingTechnologyAdvisors-node-serialport-releases-download-v6.0.4-serialport-v6.0.4-node-v46-linux-arm.tar.gz
prebuild-install http request GET https://github.com/EmergingTechnologyAdvisors/node-
serialport/releases/download/v6.0.4/serialport-v6.0.4-node-v46-linux-arm.tar.gz
prebuild-install http 404 https://github.com/EmergingTechnologyAdvisors/node-
prebuild-install WARN install No prebuilt binaries found (target=4.8.7 runtime=node arch=arm platform=linux)
make: Entering directory '/home/pi/.nvm/versions/node/v4.8.7/lib/node_modules/cncjs/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
COPY Release/serialport.node
make: Leaving directory '/home/pi/.nvm/versions/node/v4.8.7/lib/node_modules/cncjs/node_modules/serialport/build'
/home/pi/.nvm/versions/node/v4.8.7/bin/cnc -> /home/pi/.nvm/versions/node/v4.8.7/lib/node_modules/cncjs/bin/cnc
/home/pi/.nvm/versions/node/v4.8.7/bin/cncjs -> /home/pi/.nvm/versions/node/v4.8.7/lib/node_modules/cncjs/bin/cnc
/home/pi/.nvm/versions/node/v4.8.7/bin/cncjs-server -> /home/pi/.nvm/versions/node/v4.8.7/lib/node_modules/cncjs/bin/cnc
npm ERR! Linux 4.4.34-v7+
npm ERR! argv "/home/pi/.nvm/versions/node/v4.8.7/bin/node" "/home/pi/.nvm/versions/node/v4.8.7/bin/npm" "install" "-g"
"cncjs"
npm ERR! node v4.8.7
npm ERR! npm v2.15.11
npm ERR! code EPEERINVALID
npm ERR! peerinvalid The package react@15.6.2 does not satisfy its siblings' peerDependencies requirements!
npm ERR! peerinvalid Peer @trendmicro/react-anchor@0.5.6 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-breadcrumbs@0.5.5 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-buttons@1.3.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-dropdown@1.1.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-iframe@0.3.1 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-interpolate@0.5.5 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-modal@2.0.2 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-navs@0.11.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-notifications@1.0.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-paginations@0.6.1 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-popover@0.2.3 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-table@0.9.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-toggle-switch@0.5.7 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-tooltip@0.5.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer @trendmicro/react-validation@0.1.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer react-bootstrap@0.32.1 wants react@^0.14.9 || >=15.3.0
npm ERR! peerinvalid Peer react-dom@15.6.2 wants react@^15.6.2
npm ERR! peerinvalid Peer react-dropzone@4.2.7 wants react@>=0.14.0
npm ERR! peerinvalid Peer react-facebook-loading@0.6.2 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer react-grid-system@3.1.2 wants react@^16.0.0
npm ERR! peerinvalid Peer react-icon-base@2.1.2 wants react@*
npm ERR! peerinvalid Peer react-infinite-tree@0.7.1 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer react-redux@5.0.6 wants react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0
npm ERR! peerinvalid Peer react-repeatable@1.1.0 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer react-router@4.2.0 wants react@>=15
npm ERR! peerinvalid Peer react-router-dom@4.2.2 wants react@>=15
npm ERR! peerinvalid Peer react-router-redux@5.0.0-alpha.9 wants react@>=15
npm ERR! peerinvalid Peer react-select@1.2.1 wants react@^0.14.9 || ^15.3.0 || ^16.0.0-rc || ^16.0
npm ERR! peerinvalid Peer react-sortablejs@1.3.6 wants react@^0.14.0 || >=15.0.0
npm ERR! peerinvalid Peer react-tiny-virtual-list@2.1.4 wants react@15.x || 16.x
npm ERR! peerinvalid Peer react-toggle@4.0.2 wants react@^15.3.0 || ^16.0.0
npm ERR! peerinvalid Peer styled-components@3.1.5 wants react@>= 0.14.0 < 17.0.0-0
npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/npm-debug.log
pi@PCBMill:~ $ cncjs
module.js:327
throw err;
Error: Cannot find module '../dist/cnc/cnc'
at Function.Module._resolveFilename (module.js:325:15)
at Function.Module._load (module.js:276:25)
at Module.require (module.js:353:17)
at require (internal/module.js:12:17)
at Object.<anonymous> (/home/pi/.nvm/versions/node/v4.8.7/lib/node_modules/cncjs/bin/cnc:10:11)
at Module._compile (module.js:409:26)
at Object.Module._extensions..js (module.js:416:10)
at Module.load (module.js:343:32)
at Function.Module._load (module.js:300:12)
at Function.Module.runMain (module.js:441:10)
pi@PCBMill:~ $ cnc -h
module.js:327
throw err;
pi@PCBMill:~ $ cnc
module.js:327
throw err;
pi@PCBMill:~ $
Seems that the first thing that probably indicates an error are the lines....
"cncjs"
Is that telling me that npm and nodes are incompatable versions?
Also the lines beginning with ...
Is there something else that I should have loaded?
Any direction would be much appreciated.
Charlie
