fjr
[solved]sdcard 8gb, to small to dist upgrade wolfram-engine?
Fri Feb 02, 2018 4:42 pm
raspberry pi 0
raspbian
sdcard 8gb
On the sdcard is nothing more than the updated system.
Up for sudo apt-get dist-upgrade was wolfram-engine 250mb package.
Installing wolfram-engine resulted in an error about to little space
on the sdcard.
The sdcard's properties say root partition is 5.0gb.
Free space is 18mb.
Does updating require a 16gb sdcard?
If a 8gb sdcard is not big enough for updates, then how do I
uninstall the wolfram software?
Thank you.
Re: sdcard 8gb, to small to dist upgrade wolfram-engine?
Fri Feb 02, 2018 4:47 pm
Unless you are using it, its well worth uninstalling wolfram - it's slows down updates considerably if it itself needs updating as its huge.
http://raspi.tv/2016/how-to-free-up-som ... ibreoffice
W. H. Heydt
Fri Feb 02, 2018 5:41 pm
Since the uninstall solution has been suggested, I would like to address the space issue...
An 8GB card *should* be big enough to handle a full dist-upgrade. However, I have to ask...are you using a direct image install or are you using NOOBS? How much space are you using for user files? Do you ever run "sudo apt-get clean" to clear away unneeded update/upgrade files? Any one of those could reduce the free space to the point that there isn't enough to do a dist-upgrade. As an aside...I run dist-upgrade on Pis that have the full Raspbian load on them, plus a few things I like to add to any Pi I set up. I routinely use 8GB cards (and have been ever since one couldn't get a full Raspbian install onto a 4GB card). I haven't run into any space issues.
HawaiianPi
Fri Feb 02, 2018 6:44 pm
Your problem is that you installed Raspbian using NOOBS, and NOOBS uses more than 1GB if space on your card (something like 1.3-1.5GB, but I don't remember the exact number). You really should not use NOOBS if all you want is Raspbian, especially with smaller capacity cards. Note that writing a Raspbian image will wipe all data currently on the card, so either use another card or backup anything you don't want to lose.
  1. Grab the latest Raspbian image from https://www.raspberrypi.org/downloads/raspbian/
  2. Grab the Etcher software from https://etcher.io/
  3. Install Etcher and use it to write the Raspbian image to your SD card. You don't need to extract the image or format the card prior to writing. Just choose the Raspbian .zip, pick your SD card and write (if you have trouble, verify the SHA256 checksum of the download).
  4. Safely eject the card from your PC and use it to boot the Pi.
Raspbian imaged SD cards have a tiny FAT32 "boot" partition that consumes a negligible amount of space, so you get the card's full capacity for Raspbian (the root partition will be 8GB, or very close to that).
fjr
Sun Feb 04, 2018 12:29 pm
No. I ran sudo apt-get clean. It provided 1.2gb of space.
Then I could install wolfram-engine.
First I tried the image option. On a gnulinux computer I used dd
to write the image on a sdcard.
When turning on the rp 0 it would not boot. That is why I
installed raspbian using noobs.
gparted displays two big partitions. One is 1.5gb and the
second is 5.7gb.
Sun Feb 04, 2018 12:45 pm
It appears that the new "apt" command doesn't require "apt-get clean" to be run (by default, although that can be changed), but "apt-get" retains the old 'keep the files in case needed again' philosophy.
