piman1947
Can you have a wired network connection to the Pi Zero
Thu Jan 25, 2018 8:37 pm
Looking at the Raspberry Pi Zero, I noticed that it does not have a connection for a Network Cable. Is there any way that
I can connected the Pi Zero to one of the Network Connection ports on my router ?
Jerry
piglet
Re: Can you have a wired network connection to the Pi Zero
Thu Jan 25, 2018 8:39 pm
Simply: by usb hub containing a usb to network port
Less Simply: by usb hub + a usb to network adapter
They look at bit like this one. I don't know whether this one has a pi compatible chipset - so please just use it for information about the sort of thing you can get.
https://www.aliexpress.com/item/Wired-N ... 31288.html
Thu Jan 25, 2018 8:46 pm
Jerry
https://www.modmypi.com/raspberry-pi/ra ... sb-pi-zero
Retired disgracefully.....
FTrevorGowen
Thu Jan 25, 2018 10:31 pm
FWIW, some more examples of USB-to-LAN(Ethernet) Adapters tried out with various Pi's, including P0's (with an OTG "shim" uUSB adapter where necessary) can be seen here: http://www.cpmspectrepi.uk/raspberry_pi ... pters.html
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
W. H. Heydt
Thu Jan 25, 2018 10:45 pm
I have a Pi0 sitting on my desk right now that has a wired network connection. It's running headless, so that is the *only* connection it has, though it has it's own RTC, I use: https://www.monoprice.com/product?p_id=9468 with an OTG adapter added. (It's my NTP server.) There is the minor problem that it costs rather more than the Pi0, itself...
asandford
Fri Jan 26, 2018 12:16 am
Jerry
If you haven't purchased the Pi0 already, consider the Pi0W that has wifi (~£9 - less than adding any additonal hardware to a Pi0)
piman1947
Fri Jan 26, 2018 12:25 am
Thanks for all the suggestions. I've found a 3 USB port, 1 Ethernet port hub on the Adafruit web site that seems to be exactly
what I wanted.
Thanks Again
Jerry
thagrol
Fri Jan 26, 2018 5:47 pm
You can use SPI to ethernet boards too: http://raspi.tv/2015/ethernet-on-pi-zer ... on-your-pi
Slower but doesn't tie up the USB port, especially useful if you want to run the zero as a USB gadget.
This space unintentionally left blank.
