profbit
servo motor as lock
Sun Jan 21, 2018 4:35 am
Hi i have a problem with my servo motor. I’ve already googled but still doesn’t work. All I want to do is rotate my servo for 90 degrees clockwise and another code to rotate it 90 degrees counterclockwise. My gpio pin is at 36. thanks for the help
B.Goode
Re: servo motor as lock
Sun Jan 21, 2018 7:42 am
The gpiozero Python library module has built-in support for common hobbyist servos.
http://gpiozero.readthedocs.io/en/stabl ... ervo#servo
pcmanbob
Sun Jan 21, 2018 12:34 pm
This is a simple python program I wrote for some one that drives a servo from one end of its travel to the other and back again .
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(36, GPIO.OUT)
p = GPIO.PWM(36, 100)
p.start(5)
time.sleep(2)
for angle in range (25, 180):
    duty = float(angle) / 10 + 2.5
    print duty
    p.ChangeDutyCycle(duty)
    time.sleep(0.015)
for angle in range (180, 25, -1):
    print duty
    time.sleep(0.015)
from this you should be able to workout how to make you servo do what you want.
