dave-3.14159
SD card formatter 4 no longer exists?
Sat Jan 20, 2018 12:30 am
Installation instructions point us to an SD card formatter for Windows at this link:
https://www.sdcard.org/downloads/formatter_4/
However, that takes us to version *5* of the formatter. All well and good, except that *5* does not offer the "size adjustment" option. Should I be concerned?
For what it's worth, I'm a typical programmer and therefore read the documentation only after installing an OS - and I'd already selected "quick format" rather than overwriting the entire SD. All seems well so far. Could there be lurking issues because I didn't overwrite?
mahjongg
Re: SD card formatter 4 no longer exists?
Sat Jan 20, 2018 1:56 am
version 5 defaults to resize.
now the only thing you can do "wrong" is to use quick format.
dave-3.14159
Sat Jan 20, 2018 5:06 am
which I did, though so far I have not seen any consequences.
HawaiianPi
Sat Jan 20, 2018 11:50 am
Quick format works fine as long as you don't need to securely erase old data. Overwrite format is not required to recover the original card size.
Return to “Beginners”
